Hello everyone,
this is my software environment:
Windows 10
CMake 3.1
Python 3.5
Visual Studio 2017
OpenCV 4.0
Intel C++ Compiler 2017 Redistributable package for Windows
Neural Compute Stick (Myriad 2)
It says in the documentation (https://software.intel.com/en-us/articles/OpenVINO-InferEngine#vpu-stick-plugin)
that the Myriad Plugin is currently not supporting YOLOv3. Since I was testing some of the Inference Engine samples
I gave it a try anyway. I converted the YOLOv3 to the IR using the following tutorial:
software.intel.com/en-us/articles/OpenVINO-Using-TensorFlow#inpage-nav-8
Then I build a MYRIAD compatible FP16 version:
python C:/Intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/mo_tf.py --input_model F:/git/tensorflow-yolo-v3/yolo_v3.pb --tensorflow_use_custom_operations_config C:/Intel/computer_vision_sdk_2018.4.420/deployment_tools/model_optimizer/extensions/front/tf/yolo_v3.json --input_shape=[1,416,416,3] --data_type=FP16
Finally I tried to run YOLOv3 on MYRIAD 2:
object_detection_demo_yolov3_async.exe -i yolov3_demo_test_video_2.mp4 -m F:\yolov3_ir_fp16\yolo_v3.xml -d MYRIAD
Output:
InferenceEngine:
        API version ............ 1.4
        Build .................. 17328
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading plugin
        Description ....... myriadPlugin
[ INFO ] Loading network files
[ INFO ] Batch size is forced to  1.
[ INFO ] Checking that the inputs are as the demo expects
[ INFO ] Checking that the outputs are as the demo expects
[ INFO ] Loading model to the plugin
[ ERROR ] Cannot convert layer "detector/yolo-v3/ResizeNearestNeighbor"
 due to unsupported layer type "Resample"
It does not surprise that it did not work, but the error is a contradiction to what is stated in the documentation.
This source states that the "Resample" layer should be supported:
https://software.intel.com/en-us/articles/OpenVINO-InferEngine#inpage-nav-10-2-1
(Look for "Supported Layers", under column "Layers" row "Resample" and then column "MYRIAD")
Is there something I misunderstood?
B. Lange
I'm also having the exact same issue, did you manage to solve it?
My software:
- Ubuntu 16.04
 - Kernel: 4.15.0-39-generic
 - Python 3.6
 - cmake 3.5.1
 - gcc version 5.4.0 20160609
 - Neural Compute Stick 2 (MYRIAD)
 - OpenCV 3.4.2
 - openvino_toolkit v 2018.4.420
I also have this error, is there any solutions?
InferenceEngine:
[ ERROR ] Cannot convert layer "detector/yolo-v3/ResizeNearestNeighbor" due to unsupported layer type "Resample"
I also find that NCS2 is not faster than NCS1 when running ssd. Can we accelerate the ssd fps or not?
I have the same problem on ubuntu 16.04
InferenceEngine:
I have the same issue on windows 10. Is there solution for it yet?
C:\Users\trafficcountuser\Documents\Intel\OpenVINO\inference_engine_samples_2017\intel64\Release>object_detection_demo_yolov3_async.exe -i c:\\t\\s1\\v2.mp4 -m  C:\\t\\yolo_V3\\yolo_v3.xml -d MYRIAD
InferenceEngine:
There is an idea of detaching the processing before and after the unsupported layer into Tensorflow, Caffe, etc.
My sample is DeeplabV3+ instead of YoloV3, but I separated preprocessing and post processing to Tensorflow side.
https://github.com/PINTO0309/OpenVINO-DeeplabV3.git
I referred to the following repository.
Seems that this is solved now in the new SDK R5.
working on R5
