6605 Discussions
YOLOv5 output is not matching with DLStreamer openVINO python application
KarthickM
Hi all,
I have trained a model to detect seven-segment display numbers on yolov5 and I was able to convert to intel's IR model as well. Followed the following steps to convert:
python.exe yolov5\export.py --weights yolov5s640x.pt --include onnx --data customdata.yaml
python.exe mo.py --input_model yolov5s640x.onnx --model_name seven-segment-yolov5 --reverse_input_channels -s 255 --output /model.24/m.0/Conv,/model.24/m.1/Conv,/model.24/m.2/Conv
I have run the python based https://github.com/violet17/yolov5_demo (using openVINO 2021.4 )to test the IR model and the outputs are as same onnx model. Attaching the output (good) for reference.
However, when I ran the same IR model through DLstreamer, the detection is not fine. Attaching the output (bad) for reference.
I have tested in openVINO 2022 based DLstreamer as well but the results are the same.
I have used yolov5 + openVINO combination before and it all worked fine.
I doubt the yolo parsing region either has bug or I am missing something. Attaching model proc I used.
Any help would be welcome. Thank you.
Warm Regards,
Karthick
Peh_Intel
Hi Karthick,
Yes, I am able to duplicate the issue and getting the same bad inference result.
The bad inference result can be improved by resizing the image with aspect-ratio.  This can be done by defining “input_preproc” in the model-proc file.
Add the following parameter in “input_preproc”.
   "input_preproc": [
          "format": "image",
          "layer_name": "images",
          "params":
              "resize": "aspect-ratio"
The inference result looks nice now.
I attach the model-proc file as well.
Peh
Peh_Intel
Hi Karthick,
Support for Yolo-V5 was added in DL Streamer 2022.2 version:
https://github.com/dlstreamer/dlstreamer/releases/tag/2022.2-release
You can find a model-proc file now as part of the samples, here:
https://github.com/dlstreamer/dlstreamer/blob/master/samples/gstreamer/model_proc/public/yolo-v5.json
Please try to change the following parameters:
"converter": "yolo_v5",
"do_cls_softmax": true,
Peh
KarthickM
Hi Peh, @Peh_Intel ,
Thank you for the response.
One thing I forgot to write was that I had tried the same model in 2022 version as you mentioned and the results were the same (the detection was terrible).
However, the python code (The link I provided above ) works without issue.
I see the problem with only this model. I tried coco yolov5s IR converted model and that is working fine.
Warm Regards,
Karthick
Peh_Intel
Hi Karthick,
In this case, we would like to request your model (yolov5s640x.onnx) for further investigation.
Besides, please also share with us on how you run IR model through DL Streamer for our ease to duplicate.
Peh
KarthickM
Hi @Peh_Intel ,
This is the command I used to convert from pytorch to onnx.
yolov5\export.py --weights yolov5s640x.pt --include onnx --data data.yaml --batch-size 1 --nms
gst-launch-1.0 uridecodebin uri=file:/dsp/Dec-2022/TextDetection/inputMultimeter/n2.jpg ! queue ! gvadetect model=./seven-segment-yolov5.xml model-proc=./seven-segment-yolov5.json threshold=0.2 ! gvawatermark ! videoconvert ! jpegenc
! multifilesink location=./display4Orig1.jpeg
Please rename the files as below:
seven-segment-yolov5.txt ==> seven-segment-yolov5.json
yolov5s640x_Onnx.zip == > yolov5s640x.onnx
yolov5s640x_pt.zip ==> yolov5s640x.pt
Warm Regards,
Karthick
KarthickM
Hi @Peh_Intel ,
Please use the image I have used to reproduce the issue.
Warm regards,
Karthick
Peh_Intel
Hi Karthick,
Thanks for sharing. Let me duplicate from my side first.
In a meanwhile, could you also share the test image as well?
Peh
KarthickM
Hi @Peh_Intel ,
Please find the image.
Warm Regards,
Karthick
KarthickM
Hi @Peh_Intel ,
Are you able to reproduce the issue?
Warm Regards,
Karthick
Peh_Intel
Hi Karthick,
   "input_preproc": [
          "format": "image",
          "params":
Peh
KarthickM
Hi @Peh_Intel ,
Thank you very much. This has really helped us get the proper detection results.
The only thing I see is that the detected object's confidence result is 2 % down compared to python openVINO output, but that is expected I guess?
Thanks again for the quick responses.
My result:
Warm Regards,
Karthick
Peh_Intel
Hi Karthick,
I am glad that I was able to help.
Yes, a little difference is expected. By the way, you can play a trick of adjusting the threshold value to obtain the optimal performance.
Peh
KarthickM
Hi @Peh_Intel ,
Do you mean input_preproc parameters? I will adjust those parameters and see if I can improve the performance.
Warm Regards,
Karthick
Peh_Intel
Hi Karthick,
I actually mean adjust threshold value for gvadetect as I noticed that you only set threshold=0.2 ! in your previous gst-launch-1.0 command.
Peh
KarthickM
Hi @Peh_Intel ,
 I kept threshold=0.2 just to see if there was any detection. I have already fine-tuned the threshold. Thanks for all the help.
Warm Regards,
Karthick
Peh_Intel
Hi Karthick,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
