Yolo v3 not working on NCS2
Ezzat__Ahmed
Environment Info
  • Windows 10 laptop
  • Neural Compute Stick v2
  • Python 3.5
  • OpenVINO R5 (2018.R5 released in late December) for inference engine.
  • Model Optimizer from R4
  • YOLOv3 Model
  • Input Size = (320, 320)
Problem #1: NCS2 Wrong Inference Output for YOLOv3
I can run the YOLOv3 object detector successfully on the NCS v1, but the test failed on NCS v2. I tried other object detectors (SSD_MobileNetv1, SSD_Inceptionv2) and they are working fine on both NCS sticks. The NCS2 gives wrong output. I cannot figure out the difference in case of the YOLOv3 model between the 2 stick versions.
 I attached the code along with the model I am using. You only need to run "python yolov3_test.py" and the code will run inference on the famous image "dog.jpg" and finally draws the bboxes on the image (you need to press a key to end the program).
Problem #2: Model Optimizer Problem in R5
I have a problem with the Model Optimizer in the R5 release. All models generated with R5 model_optimizer are not working at all on any device (NCS1, NCS2 and GPU).
Using the Model Optimizer from R4 (while keep using the inference engine from R5) is working well for me on all devices.
Please help me to solve the 2 issues.
Ahmed Ezzat
Hyodo__Katsuya
Innovator
- My environment
OpenVINO R5 5.0.1
Ubuntu 16.04
- NCS1
- NCS2
Ezzat__Ahmed
That is exactly what I am seeing.
nikos1
Valued Contributor I
Hi Ahmed,
 > Problem #2: Model Optimizer Problem in R5
Looks like an installation / environment issue causing mixed env picking up wrong libraries.
I would uninstall all SDKs old and new, reboot and clean re-install the very latest. Then please try to build and run the samples, do they work? Then I would use the model optimizer again for more extensive tests. Post here command line and output logs in case of issues.
Cheers,
nikos
Ezzat__Ahmed
Hi nikos,
For problem #1, the model is working on NCS1 but output garbage on NCS2 for the attached binary. The model optimizer is , for me, a side problem for now.
Do you have any IDEA? Is this a problem in the plugin library of NCS2?
Ahmed
hamze60
Hi Ahmed,
I got also a NCS2, using it with OpenVino R5. I could run some Object Detections on it. You can refer to this thread to see our discussion about Mobilnet+SSD object detections. Actually I could easily convert a caffe model to IR and easily use it (even you do not need to convert caffe model to IR, they are converted internally). Reading inference result of IR model was same as original Caffe model.
However, for Yolo3, I have also problem. I could convert the model to IR, but can use inference result. it's format is changed.... I asked a question here and wait for help.
g
Ezzat__Ahmed
nikos wrote:
Hi Ahmed,
Cheers,
nikos
I installed the latest SDK (R5.01) on Ubuntu, recompiled the yolov3 model and I still get corrupted results on both NCS1 and 2 (This is for the model optimizer issue). I attached the new xml file generated from the model optimizer 1.5.12 which is different from the original model generated from model optimizer 1.4.
In conclusion,
# The yolov3 file generated by model optimizer 1.4.x is working fine on NCS1 but not NCS2.
# The file generated from model optimizer 1.5.12 is not working fine at both NCS sticks.
Ahmed
Ezzat__Ahmed
Dear Intel guys,
Please I need help in this issue. It is blocking me from completing a protoype for demo.
Can you please have a look?
Ahmed
hamze60
Hi Ahmed,
Do you have any update? it is around 2 months that  I got stuck with this Yolo3+NCS2. Then for now I moved to Mobilnet+SSD. that works fine with around 20-25 FPS.
Ezzat__Ahmed
Hi Hamzeh,
I think there is  an internal problem in the NCS2 inference engine plugin running the YOLO.
see https://software.intel.com/en-us/node/805425 for more information.
I changed the negative slope as noticed (changed to be 0.101) and I got some improvement, but still a lot of false positives.
Ahmed
hamze60
Hi again Ahmed,
Sorry, this site did not send me email notification, and I did not notice your message (but I was waiting for it!).
I am not DNN expert, and I don't know what is the exact source of problem of Yolov3 on NCS2, its architecture, or incompatibility of Darknet model type.
Then I tried to find caffe model of Yolov3, and the only promising one I found was this one. It works fine on Ubuntu, but can't be ported to NCS2, because the guy wrote the model in a way that can be read only with caffe.net reader method, (not cv2.dnn.readnet), and then I could not use it on NCS2 (refer to forum of that page to see discussions). There is something called "Caffe python layer" there...
Have you tried Pinto project? while ago, I checked it but it had accuracy problem too. But he had some updates a few days ago, and I am going to test it.
if it is not working, I guess it is better to not waste time on this, and wait for some update from intel. and I continue to use older and less accurate Mobilent+SSD over NCS2 which works very well.
Nguyen__Anh_Minh
has anyone been able to find out the problem of this?
I'm facing the same issue here as my model works the Movidius NCS. Then I bought the NCS2 to give the model a boost but the output from exec_net are not the same anymore and this is causing thousands of false positive.
When trying the NCS2 with the model from this repo here https://github.com/PINTO0309/OpenVINO-YoloV3 it worked fine.
Leini__Mikk
I run into similar issue. I converted pretrained darknet COCO and Openimages models to IR (FP16) and that works on NCS2. But when i convert my own trained model, it gives lot of false positives. Same issue on Windows and on RPi. However if i convert my darknet model to IR FP32 then that works (inference on CPU). So i guess it has something to do with float conversion.
Tsin__Ross
Mine is the same.
Hyodo, Katsuya wrote:
- My environment
OpenVINO R5 5.0.1
Ubuntu 16.04
- NCS1
- NCS2
Tsin__Ross
Hi Nikos,
Could you help me with the questions in this thread?
Thank you.
nikos wrote:
Hi Ahmed,
Cheers,
nikos
Leini__Mikk
I found a solution for my issue. I was using the older 2018 year version of Openvino. When i upgraded to 2019 R1 then there was no more false positives. Looks like the issue was in the Myriad plugin or somewhere else in the inference code but not in the model or model converter because i was able to use the "old" IR files with updated SW.
Release description also says that some things have been fixed/improved:
https://software.intel.com/en-us/articles/OpenVINO-RelNotes#inpage-nav-2-4-5
Shubha_R_Intel
Hello everyone. Please see this thread. I just tested yolov3 on OpenVino 2019 R1, it works fine.
https://software.intel.com/en-us/forums/computer-vision/topic/807383
Shubha
