YoloV2 NCS - C++
I need to create a software in C++ that use Movidius NCS to detect objects with tiny yolo v2.
I saw this example with python and C++ https://github.com/duangenquan/YoloV2NCS and i used Region class in my project.
I don't know why but I have many false detections and 18.000 results from mvncGetResults().
Using dog.jpg for example i have a lot of output like these:
14 = person , prob = 0.309372
0 = aeroplane , prob = 0.32841
0 = aeroplane , prob = 0.346906
5 = bus , prob = 0.334437
17 = sofa , prob = 0.374106
10 = diningtable , prob = 0.461306
15 = pottedplant , prob = 0.489467
18 = train , prob = 0.287603
17 = sofa , prob = 0.375134
8 = chair , prob = 0.28799
9 = cow , prob = 0.290264
3 = boat , prob = 0.432494
2 = bird , prob = 0.564795
19 = tvmonitor , prob = 0.266686
5 = bus , prob = 0.760655
10 = diningtable , prob = 0.521631
1 = bicycle , prob = 0.411501
I think it's something with preprocessing or with conversion in float16 (I used fp16 code taken from GitHub mvnc examples) but I don't really know how to solve these problems.
I hard coded some values for Region.getDetection taking them from python code ObjectWrapper.py of YoloV2NCS.
Here is the inference part of the code (I used Qt in my project and width = height = 416):
void NCSNet::preprocess_image(const cv::Mat& src_image_mat, cv::Mat& preprocessed_image_mat) { cv::Mat resized(width, height, CV_8UC3); if (src_image_mat.channels()==4) cv::cvtColor(src_image_mat, src_image_mat, CV_BGRA2BGR); cv::resize(src_image_mat, resized, cv::Size(width, height)); cv::cvtColor(resized,resized, CV_BGR2RGB); resized.convertTo(preprocessed_image_mat, CV_32FC3, 1.0/255.0); } void NCSNet::DoInferenceOnImage(void* graphHandle, cv::Mat& inputMat) { mvncStatus retCode; cv::Mat preprocessed_image_mat(width, height,CV_32FC3); preprocess_image(inputMat, preprocessed_image_mat); if (preprocessed_image_mat.rows > width || preprocessed_image_mat.cols > height) { qCritical() << "Error - preprocessed image is unexpected size!"; return; } half tensor16[width* height * 3]; floattofp16((unsigned char*)tensor16, (float*)preprocessed_image_mat.data, width*height*3); unsigned int lenBufFp16 = 3*width*height*sizeof(half); retCode = mvncLoadTensor(graphHandle, tensor16, lenBufFp16, NULL); if (retCode != MVNC_OK) { qCritical() << "Error - Could not load tensor\n"; qCritical() << " mvncStatus from mvncLoadTensor is: " << retCode; return; } void* resultData16; void* userParam; unsigned int lenResultData; retCode = mvncGetResult(graphHandle, &resultData16, &lenResultData, &userParam); if (retCode != MVNC_OK) { qCritical() << "Error - Could not get result for image "; qCritical() << " mvncStatus from mvncGetResult is: " << retCode; return; } // convert half precision floats to full floats int numResults = lenResultData / sizeof(half); qDebug() << "numResults: " << numResults; float* resultData32; resultData32 = (float*)malloc(numResults * sizeof(*resultData32)); fp16tofloat(resultData32, (unsigned char*)resultData16, numResults); std::vector<DetectedObject> obj; Region region; region.GetDetections(resultData32, 125, 12, 12, 20, width, height, 0.25, 0.4, 13, obj); for(DetectedObject o : obj){ qDebug() << o.objType << " = " << o.name.c_str() << ", prob = " << o.confidence; } mvncDeallocateGraph(graphHandle); mvncCloseDevice(deviceHandle); }
It is a test, so is written horribly and I'm sorry for it.
Can you help me?
@Doch It's tough to tell from looking at this code alone. Can you send me a link to your code and your model so that I may debug the issue? Thanks.
Here's a link with the code and the graph: https://dropbox.com/s/mqgcgublnsnsoun/YoloNCS.tar.gz?dl=0.
In the meantime I changed a bit the code because I tried without success some things; I also removed Qt dependence.
I wrote and modified only main.cpp, ncsnet.h and ncsnet.cpp, other files are copied as they are from examples.
Edit: I tried the same graph file with duangenquan's YoloV2NCS and it works fine.
Any ideas?
Hi Doch,
I think you're missing the following line code:
out = self.Reshape(out, self.dim)
referring to orginal python source.
Basically it does a Mat transpose that seems mandatory to get good results.
Try to comment out the line in the original code and you'll find (more or less) results similar to yours.
Then I advice you to migrate to NCSDK2.
You could try starting from SqueezeNet Caffe example.
I think you'll have to migrate original ObjectWrapper.PrepareImage method to provide to NCS same data as python example.
F__
Thanks!
As soon as I can I try to implement that line and I'll let you know if it works.
I've to try this process to with bad result.
Have you got new about this code?
Process getResult give me strange result..
"out = self.Reshape(out, sefldim)" where I must to put this line code ?
Thank's
Right.
NCSDK 2 work very well.
Result give a float* pointer. Finish bad subroutine convertion float16.
I can finally work with my c++
