Yolov3
I try to convert yolov3-tiny to caffe. The prototxt like https://github.com/Amalle/Yolov3_caffe/blob/master/models/caffe/yolov3-tiny.prototxt
And I convert the graph using the following:
$ mvNCCompile models/caffe/yolov3-tiny.prototxt -w models/caffe/yolov3-tiny.caffemodel -s 12 -ec mvNCCompile v02.00, Copyright @ Intel Corporation 2017 /usr/local/bin/ncsdk/Controllers/FileIO.py:65: UserWarning: You are using a large type. Consider reducing your data sizes for best performance Blob generated
But the predicted result size was wrong.
Then I try mvNCProfile:
$ mvNCProfile models/caffe/yolov3-tiny.prototxt -w models/caffe/yolov3-tiny.caffemodel -ec mvNCProfile v02.00, Copyright @ Intel Corporation 2017 /usr/local/bin/ncsdk/Controllers/FileIO.py:65: UserWarning: You are using a large type. Consider reducing your data sizes for best performance Blob generated USB: Transferring Data... /usr/local/lib/python3.5/dist-packages/mvnc/mvncapi.py:420: DeprecationWarning: The binary mode of fromstring is deprecated, as it behaves surprisingly on unicode inputs. Use frombuffer instead Time to Execute : 266.8 ms USB: Myriad Execution Finished Time to Execute : 248.16 ms USB: Myriad Execution Finished Traceback (most recent call last): File "/usr/local/bin/mvNCProfile", line 156, in <module> profile_net(args.network, args.inputnode, args.outputnode, args.nshaves, args.inputsize, args.weights, args.device_no, args.explicit_concat, args.ma2480, args.scheduler, args) File "/usr/local/bin/mvNCProfile", line 142, in profile_net timings, myriad_output = run_myriad(graph_file, args) File "/usr/local/bin/ncsdk/Controllers/MiscIO.py", line 248, in run_myriad myriad_output = myriad_output.reshape(sz[1], sz[2], sz[3]) ValueError: cannot reshape array of size 41308 into shape (1,1,215475)
@Tome_at_Intel
@maqiao Looks like this Tiny Yolo v3 uses a concat as the last layer. There is a known issue where the NCSDK has issues with models having concat as the last layer. Some users have found work arounds by using dummy reshape layers https://ncsforum.movidius.com/discussion/comment/2831/#Comment_2831. Try this and let me know if this works for you.
@Tome_at_Intel Thanks
I have try that. It can't works for me.
The last three layers as following:
layer { name: "conv13_perm" type: "Permute" bottom: "conv13" top: "conv13_perm" permute_param { order: 0 order: 2 order: 3 order: 1 } } layer { name: "conv13_flat" type: "Flatten" bottom: "conv13_perm" top: "conv13_flat" flatten_param { axis: 1 } } layer { name: "output" type: "Concat" bottom: "conv13_flat" bottom: "conv10_flat" top: "output" concat_param { axis: 1 } }
Try this:
$ mvNCProfile models/caffe/yolov3-tiny.prototxt -w models/caffe/yolov3-tiny.caffemodel -s 12 -on conv13_perm -ec
Blob generated
USB: Transferring Data…
Time to Execute : 216.87 ms
Time to Execute : 197.8 ms
USB: Myriad Connection Closing.
USB: Myriad Connection Closed.
Network Summary
Detailed Per Layer Profile
Bandwidth time
Name MFLOPs (MB/s) (ms)
0 data 0.0176147.1 0.006
1 scale1 149.5 1175.5 7.582
2 pool1 2.8 792.4 6.666
3 scale2 398.7 859.5 13.839
4 pool2 1.4 926.3 2.851
5 scale3 398.7 648.0 9.226
6 pool3 0.7 957.8 1.379
7 scale4 398.7 403.3 7.717
8 pool4 0.3 947.6 0.697
9 scale5 398.7 203.8 10.051
10 pool5 0.2 924.2 0.357
11 scale6 398.7 323.6 9.250
12 pool6 0.4 411.4 0.401
13 crop6 0.0 2180.1 0.088
14 scale7 1594.9 314.8 33.309
15 scale8 88.6 331.9 2.501
16 scale9 398.7 323.5 9.252
17 conv10 44.1 311.0 1.332
18 scale11 11.1 441.6 0.328
19 scale11_s0 0.0 33.8 0.010
20 upsample_p0 0.0 156.4 0.264
21 scale11_s1 0.0 38.7 0.009
273 scale11_s127 0.0 38.2 0.009
274 upsample_p127 0.0 158.2 0.261
275 pool_deconv 0.1 566.3 0.292
276 route 0.0 1950.4 0.085
277 route_scale5 0.0 2094.7 0.158
278 scale12 1196.2 210.3 29.215
279 conv13 88.3 197.3 2.305
280 conv10_perm 0.0 310.1 0.265
281 conv10_flat 0.0 179.6 0.458
282 conv13_perm 0.0 182.7 1.800
Total inference time 186.13
Generating Profile Report 'output_report.html'…
But, the following was wrong:
$ mvNCProfile models/caffe/yolov3-tiny.prototxt -w models/caffe/yolov3-tiny.caffemodel -s 12 -on conv13_flat -ec
Blob generated
Segmentation fault (core dumped)
I trying to use yolov3-tiny model for Movidius but i checked release note for ncsdk v2.08.01 yolov3 is not being enlisted in the list of supported models.
Does it means i cannot use yolo v3 model with movidius stick with new ncsdk?
I tested every possible way in which i can use yolov3 tiny model with movidius stick i was able to get the prototxt file and caffemodel as well.But it don't work.
Is there any possible way i can use the yolov3-tiny model with movidius stick?
