accuracy_checker ERROR: 2
Aurjay
I get these errors for certain tasks in my project. Can someone help find the reason for this error and possible solutions to try?
Wan_Intel
Hi Aurjay,
Could you please share the following information with us for further investigation?
·      Which version of the OpenVINO™ toolkit are you using?
·      Could you please share your source model and custom model with us?
·      Could you please share the config file you used with the Accuracy Checker?
·      Could you share the command you use to run Accuracy Checker?
Wan
Aurjay
The version of openvino is 2021
The version of accuracy checker is 0.8.7
config file format :
models:
    - name: resnet_50
      launchers:
        - framework: dlsdk
          device: CPU
          model: "model .xml file path"
          weights: "model .bin file path"
          adapter: ssd
          batch: 8
      datasets:
          - name: Task_1
            data_source: "data img folder path"
            annotation_conversion:
              converter: mscoco_detection
              annotation_file: "annotations.json path"
              dataset_meta_file: "datasetmeta.json path"
            preprocessing:
            - type: resize
              dst_width: 544
              dst_height: 320
            postprocessing:
            - type: resize_prediction_boxes
            metrics:
            - type: map
            - type: coco_precision
Accuracy check command:
accuracy_check -c "path to config.yml" -m "path to model" --log_file "path to log.txt"
Btw. The logs getting saved in log.txt is getting saved for each dataset individually. Is there a way to get a average value because for example individual map values are not helpful but the average of map values for all the dataset is helpful to analyze the model performance.
Wan_Intel
Hi Aurjay,
Thanks for your information.
For your information, you can refer to Metrics in Deep Learning accuracy validation framework to compare predicted data with annotated data and perform quality measurement. On another note, you may refer to resnet-50-tf accuracy check yml file and resnet-50-pytorch accuracy check yml file to see how to prepare yml file for resnet model. On the other hand, could you please share your log.txt file, resnet_50 model and dataset with us for further investigation?
Wan
Wan_Intel
Hi Aurjay,
Thanks for your question.
This thread will no longer be monitored since we have provided suggestions.
If you need any additional information from Intel, please submit a new question.
Wan
