can custom models run on the OpenVINO ?
skyravn
we will never use any of the pre-made ones in the listed models in took kit-
IntelSupport
Community Manager
Hi Brent,
OpenVINO able to run custom models. The models should contain layers that are supported by the OpenVINO toolkit.
The list of known layers is different for each of the supported frameworks. To see the layers supported by your framework, refer to the following link:
https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_Supported_Frameworks_Layers.html
To see the layers that are supported by each device plugin for the Inference Engine, refer to the following link:
https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_supported_plugins_Supported_Devices.html#supported_layers
Adli
Adli
Hi Brent,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Adli
