cannot build openvino
lberger
I tried to build openvino. I started here
cd /c/lib
git clone -b 2022.3.0 https://github.com/openvinotoolkit/openvino.git
cd openvino
git submodule update --init --recursive
cd /c/lib/build
mkdir openvino
cd openvino
cmake -G "Visual Studio 17 2022" -DCMAKE_BUILD_TYPE=Release -DENABLE_OPENCV=ON -DOpenCV_DIR=/c/install/opencv /c/lib/openvino
cmakeoutput is
-- The C compiler identification is MSVC 19.35.32215.0
-- The CXX compiler identification is MSVC 19.35.32215.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.35.32215/bin/Hostx64/x64/cl.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.35.32215/bin/Hostx64/x64/cl.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- OpenVINO version is 2022.3.0 (Build 9052)
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - not found
-- Found Threads: TRUE
-- Trying to find apivalidator in: C:/Program Files (x86)/Windows Kits/10/bin/10.0.22621.0/x64
-- OpenVINO Runtime enabled features:
--     CI_BUILD_NUMBER: 2022.3.0-9052-9752fafe8eb-HEAD
--     ENABLE_LTO = OFF
--     OS_FOLDER = OFF
--     USE_BUILD_TYPE_SUBFOLDER = OFF
--     TREAT_WARNING_AS_ERROR = ON
--     ENABLE_INTEGRITYCHECK = OFF
--     ENABLE_SANITIZER = OFF
--     ENABLE_UB_SANITIZER = OFF
--     ENABLE_THREAD_SANITIZER = OFF
--     ENABLE_COVERAGE = OFF
--     ENABLE_SSE42 = ON
--     ENABLE_AVX2 = ON
--     ENABLE_AVX512F = ON
--     BUILD_SHARED_LIBS = ON
--     ENABLE_LIBRARY_VERSIONING = OFF
--     ENABLE_FASTER_BUILD = OFF
--     ENABLE_CPPLINT = OFF
--     ENABLE_CPPLINT_REPORT = OFF
--     ENABLE_CLANG_FORMAT = OFF
--     ENABLE_NCC_STYLE = OFF
--     VERBOSE_BUILD = OFF
--     ENABLE_UNSAFE_LOCATIONS = OFF
--     ENABLE_FUZZING = OFF
--     ENABLE_INTEL_CPU = ON
--     ENABLE_TESTS = OFF
--     ENABLE_COMPILE_TOOL = ON
--     ENABLE_STRICT_DEPENDENCIES = ON
--     ENABLE_CLDNN = ON
--     ENABLE_INTEL_GPU = ON
--     ENABLE_ONEDNN_FOR_GPU = ON
--     ENABLE_PROFILING_ITT = OFF
--     ENABLE_PROFILING_FILTER = ALL
--     ENABLE_PROFILING_FIRST_INFERENCE = ON
--     SELECTIVE_BUILD = OFF
--     ENABLE_ERROR_HIGHLIGHT = ON
--     ENABLE_DOCS = OFF
--     ENABLE_PKGCONFIG_GEN = OFF
--     THREADING = TBB
--     ENABLE_TBBBIND_2_5 = ON
--     ENABLE_INTEL_GNA = ON
--     ENABLE_IR_V7_READER = ON
--     ENABLE_GAPI_PREPROCESSING = ON
--     ENABLE_MULTI = ON
--     ENABLE_AUTO = ON
--     ENABLE_AUTO_BATCH = ON
--     ENABLE_HETERO = ON
--     ENABLE_TEMPLATE = ON
--     ENABLE_INTEL_MYRIAD_COMMON = ON
--     ENABLE_INTEL_MYRIAD = ON
--     ENABLE_MYRIAD_NO_BOOT = OFF
--     ENABLE_GAPI_TESTS = OFF
--     GAPI_TEST_PERF = OFF
--     ENABLE_MYRIAD_MVNC_TESTS = OFF
--     ENABLE_DATA = OFF
--     ENABLE_BEH_TESTS = OFF
--     ENABLE_FUNCTIONAL_TESTS = OFF
--     ENABLE_SAMPLES = ON
--     ENABLE_OPENCV = ON
--     ENABLE_V7_SERIALIZE = OFF
--     ENABLE_TBB_RELEASE_ONLY = OFF
--     ENABLE_SYSTEM_PUGIXML = OFF
--     ENABLE_SYSTEM_TBB = OFF
--     ENABLE_DEBUG_CAPS = OFF
--     ENABLE_GPU_DEBUG_CAPS = OFF
--     ENABLE_CPU_DEBUG_CAPS = OFF
--     ENABLE_OV_ONNX_FRONTEND = ON
--     ENABLE_OV_PADDLE_FRONTEND = ON
--     ENABLE_OV_IR_FRONTEND = ON
--     ENABLE_OV_TF_FRONTEND = ON
--     ENABLE_SYSTEM_PROTOBUF = OFF
--     ENABLE_OV_CORE_UNIT_TESTS = OFF
--     ENABLE_OPENVINO_DEBUG = OFF
--     ENABLE_REQUIREMENTS_INSTALL = OFF
-- MODELS_PATH=
-- PROJECT ............................... OpenVINO
-- CMAKE_VERSION ......................... 3.26.1
-- CMAKE_BINARY_DIR ...................... C:/lib/build/openvino
-- CMAKE_SOURCE_DIR ...................... C:/lib/openvino
-- OpenVINO_SOURCE_DIR ................... C:/lib/openvino
-- OpenVINO_BINARY_DIR ................... C:/lib/build/openvino
-- CMAKE_GENERATOR ....................... Visual Studio 17 2022
-- CMAKE_C_COMPILER_ID ................... MSVC
-- CMAKE_CXX_COMPILER_ID ................. MSVC
-- CMAKE_BUILD_TYPE ...................... Release
-- CMAKE_TOOLCHAIN_FILE ..................
-- GLIBC_VERSION....... .................. 0.0
-- Looking for secure_getenv
-- Looking for secure_getenv - not found
-- Looking for __secure_getenv
-- Looking for __secure_getenv - not found
-- The name openvino::pugixml is an ALIAS for pugixml-static. It will be exported to the OpenVINODeveloperPackage with the original name.
-- The name gflags is an ALIAS for gflags_nothreads_static. It will be exported to the OpenVINODeveloperPackage with the original name.
-- Protocol Buffers Configuring...
-- 3.18.2.0
-- Configuration script parsing status [
--   Description : Protocol Buffers
--   Version     : 3.18.2.0 (3.18.2)
--   Contact     : protobuf@googlegroups.com
-- Protocol Buffers Configuring done
-- Found PythonInterp: C:/Program Files/Python310/python.exe (found version "3.10.10")
-- Found PythonLibs: optimized;C:/Program Files/Python310/libs/python310.lib;debug;C:/Program Files/Python310/libs/python310_d.lib (found version "3.10.10")
Generated: C:/lib/build/openvino/thirdparty/onnx/onnx/onnx/onnx_openvino_onnx-ml.proto
Generated: C:/lib/build/openvino/thirdparty/onnx/onnx/onnx/onnx-operators_openvino_onnx-ml.proto
Generated: C:/lib/build/openvino/thirdparty/onnx/onnx/onnx/onnx-data_openvino_onnx.proto
-- ******** Summary ********
--   CMake version             : 3.26.1
--   CMake command             : C:/Program Files/CMake/bin/cmake.exe
--   System                    : Windows
--   C++ compiler              : C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.35.32215/bin/Hostx64/x64/cl.exe
--   C++ compiler version      : 19.35.32215.0
--   CXX flags                 : /DWIN32 /D_WINDOWS /W3 /GR /EHsc -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /EHsc /Gy /bigobj /MP /wd4251 /wd4275 /wd4244 /EHsc /wd26812
--   Build type                : Release
--   Compile definitions       : IE_BUILD_POSTFIX="$<$<CONFIG:Debug>:d>$<$<CONFIG:Release>:>";ENABLE_INTEL_CPU=1;__STDC_FORMAT_MACROS
--   CMAKE_PREFIX_PATH         :
--   CMAKE_INSTALL_PREFIX      : C:/Program Files (x86)/OpenVINO
--   CMAKE_MODULE_PATH         :
--   ONNX version              : 1.12.0
--   ONNX NAMESPACE            : openvino_onnx
--   ONNX_USE_LITE_PROTO       : ON
--   USE_PROTOBUF_SHARED_LIBS  : OFF
--   Protobuf_USE_STATIC_LIBS  : ON
--   ONNX_DISABLE_EXCEPTIONS   : OFF
--   ONNX_WERROR               : OFF
--   ONNX_BUILD_TESTS          : OFF
--   ONNX_BUILD_BENCHMARKS     : OFF
--   ONNXIFI_DUMMY_BACKEND     : OFF
--   ONNXIFI_ENABLE_EXT        : OFF
--   Protobuf compiler         :
--   Protobuf includes         :
--   Protobuf libraries        :
--   BUILD_ONNX_PYTHON         : OFF
-- Using the multi-header code from C:/lib/openvino/thirdparty/json/nlohmann_json/include/
-- TBB (2020.2) is found at C:/lib/openvino/temp/tbb/cmake
-- Static tbbbind_2_5 package is found
-- The name openvino::itt is an ALIAS for itt. It will be exported to the OpenVINODeveloperPackage with the original name.
-- The name openvino::conditional_compilation is an ALIAS for conditional_compilation. It will be exported to the OpenVINODeveloperPackage with the original name.
-- The name ngraph::builder is an ALIAS for ngraph_builders. It will be exported to the OpenVINODeveloperPackage with the original name.
-- The name ngraph::reference is an ALIAS for ngraph_reference. It will be exported to the OpenVINODeveloperPackage with the original name.
-- The name openvino::core::dev is an ALIAS for ov_core_dev. It will be exported to the OpenVINODeveloperPackage with the original name.
-- DNNL_TARGET_ARCH: X64
-- DNNL_LIBRARY_NAME: dnnl
-- Could NOT find Doxyrest (missing: DOXYREST_EXECUTABLE)
-- Found PythonInterp: C:/Program Files/Python310/python.exe (found suitable version "3.10.10", minimum required is "2.7")
-- Could NOT find Sphinx (missing: SPHINX_EXECUTABLE)
-- Found Git: C:/Program Files/Git/mingw64/bin/git.exe (found version "2.39.2.windows.1")
-- Enabled workload: INFERENCE
-- Enabled primitives: CONVOLUTION;DECONVOLUTION;CONCAT;LRN;INNER_PRODUCT;MATMUL;POOLING;REDUCTION;REORDER;RNN;SOFTMAX
-- Enabled primitive CPU ISA: ALL
-- Enabled primitive GPU ISA: ALL
-- Primitive cache is disabled
-- The ASM_MASM compiler identification is MSVC
-- Found assembler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.35.32215/bin/Hostx64/x64/ml64.exe
-- Found PythonInterp: C:/Program Files/Python310/python.exe (found suitable version "3.10.10", minimum required is "3")
-- The name openvino::runtime::dev is an ALIAS for openvino_dev. It will be exported to the OpenVINODeveloperPackage with the original name.
-- Found PythonLibs: C:/Program Files/Python310/libs/python310.lib
CMake Warning at src/bindings/python/CMakeLists.txt:90 (message):
  Python module 'cython>=0.29.22' is missed, IE Python API 1.0 will not be
  built (ENABLE_PYTHON is OFF)
Call Stack (most recent call first):
  src/bindings/python/CMakeLists.txt:111 (ov_check_python_build_conditions)
-- Found CUDA: C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v12.1 (found suitable exact version "12.1")
CMake Error at C:/Program Files/CMake/share/cmake-3.26/Modules/FindOpenCL.cmake:51 (if):
  if given arguments:
    "EXISTS" "C:/lib/openvino/thirdparty/ocl/cl_headers" "C:/lib/openvino/thirdparty/ocl/clhpp_headers/include/Headers/cl.h"
  Unknown arguments specified
  C:/Program Files/CMake/share/cmake-3.26/Modules/FindOpenCL.cmake:95 (_FIND_OPENCL_VERSION)
  samples/cpp/benchmark_app/CMakeLists.txt:84 (find_package)
-- Configuring incomplete, errors occurred!
What's wrong in my configuration?
Peh_Intel
Hi lberger,
For your CMake warning, you can install Cython package (pip install cython==0.29.22) before building OpenVINO.
Regarding your CMake error, it seems like you have NVIDIA GPU instead of iGPU. In this case, disable the GPU plugin in building OpenVINO.
cmake -G "Visual Studio 17 2022" -DCMAKE_BUILD_TYPE=Release -DENABLE_OPENCV=ON -DENABLE_INTEL_GPU=OFF -DOpenCV_DIR=/c/install/opencv /c/lib/openvino
Peh
lberger
I deleted build repo and run
It works configuration and compilation.
About Cython I want to use openvino with opencv in c++ I think I don't need cython Am I right?
-- ENABLE_LTO = OFF
-- OS_FOLDER = OFF
-- ENABLE_AVX2 = ON
-- ENABLE_INTEL_GPU = OFF
-- THREADING = TBB
-- ENABLE_AUTO = ON
-- MODELS_PATH=
-- 3.18.2.0
-- System : Windows
-- Register template to be built in build-modules/template
-- Register template_extension to be built in build-modules/template_extension
-- Looking for CL_VERSION_3_0
-- Looking for CL_VERSION_3_0 - found
-- Found OpenCL: C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v12.1/lib/x64/OpenCL.lib (found version "3.0")
CMake Warning at tools/mo/CMakeLists.txt:5 (message):
Please enable OpenVINO Runtime Python API (set -DENABLE_PYTHON=ON) targets
to enable Model Optimizer target
CMake Warning at cmake/developer_package/shellcheck/shellcheck.cmake:22 (message):
shellcheck tool is not found
scripts/CMakeLists.txt:31 (ie_shellcheck_process)
-- Configuring done (6.9s)
-- Generating done (1.5s)
-- Build files have been written to: C:/lib/build/openvino
Peh_Intel
Hi lberger,
Yes, you’re right. You can proceed to build OpenVINO.
Peh
Peh_Intel
Hi lberger,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Peh
