6616 Discussions
crash at Graph.queue_inference_with_fifo_elem() when mobile_ssd runs for a while
I install NCSDK2 both on my X86 desktop and arm64 device.
My mobile ssd network program works out fine on X86 for 18 hours, but the program together with the armbian system will crash everytime running about 20mins on arm64.
The program always fail at Graph.queue_inference_with_fifo_elem(). I guess there's something to do with memory management of NCSDK2.
Anybody meet the same problem?
Hi @distillation
Does the program run successfully and then crash after 20 minutes? Or does it not run at all?
If you are using a Raspberry Pi 3, you be running Raspbian Stretch. See the NCSDK installation prerequisites here
Sahira
