6605 Discussions
device.open() Exception: Status.INVALID_HANDLE
I installed the NCAPI v2 and I am modifing my software made for NCAPI v1 for running with the new Movidius stick.
I correcly recognize the device but when I try to open it an error appear.
devices = mvnc.enumerate_devices()
device = mvnc.Device(devices[0])
device.open()
and at this level compare an exception (raise Exception(Status(status)))
Where could be the problem ? I am using a NUC.
Best
Fabio
Hi @norbaf
The Neural Compute SDK does not support the Intel Neural Compute Stick 2, you will need to use the OpenVINO toolkit. Take a look at the following guide for transitioning from the NCSDK to the OpenVINO toolkit.
https://software.intel.com/en-us/articles/transitioning-from-intel-movidius-neural-compute-sdk-to-openvino-toolkit
Jesus
Hi Jesus,
thanks for your answer. Is a mistake using "NCAPI v2" for the stick "Neural Compute Stick 2" ?
Because for what I have understand reading on the web about the Movidius stick, for the new one you need to use the new API version with few modification in the code from v1 to v2. Why this is not possible ? I would like to do the smallest change are possible to migration from "Neural Compute Stick 1" to "Neural Compute Stick 2"
Best
norbaf
Hi @norbaf
The NCSDK v1 and V2 only have support for the original Intel Movidius Neural Compute Stick 2. Could you share the link to the documentation that was misleading?
Take a look at the following guide to help you transition from the Neural Compute SDK to the OpenVINO toolkit.
Jesus
