6605 Discussions
docker build in SDK 2.04.00 fails with `wget` errors
I have been trying to use the new Dockerfile in SDK 2.04.00 to build a container but the build eventually fails with a wget related error:
Connecting to downloadmirror.intel.com (downloadmirror.intel.com)|23.44.100.6|:443... connected. ERROR: cannot verify downloadmirror.intel.com's certificate, issued by 'CN=DigiCert SHA2 Secure Server CA,O=DigiCert Inc,C=US': Unable to locally verify the issuer's authority. To connect to downloadmirror.intel.com insecurely, use `--no-check-certificate'. Installation failed: Command 'wget --no-cache -O NCSDK-2.04.00.06.tar.gz https://downloadmirror.intel.com/27738/eng/NCSDK-2.04.00.06.tar.gz' return code=5. Error on line 308 in ./install-utilities.sh. Will exit Makefile:47: recipe for target 'install' failed make: *** [install] Error 131
This happens both if I do docker build -t ncsdk -f ./extras/docker/Dockerfile https://github.com/movidius/ncsdk.git#ncsdk2 or clone the repo first and issue docker build -t ncsdk -f ./extras/docker/Dockerfile ..
What worked for me was cloning the repo first, then manually running the wget command wget --no-cache -O NCSDK-2.04.00.06.tar.gz https://downloadmirror.intel.com/27738/eng/NCSDK-2.04.00.06.tar.gz' which works fine on its own and then running the docker build command.
Hi @milad, thanks for reporting this. We are working on getting a fix out for it. In the meantime it should work if you remove the "--no-install-recommends" flag from the apt install command on line 4 of the Dockerfile.
In addition, for anyone downloading on a Ubuntu system that gets the same error:
-Open the file install.sh in gedit
-ctrl+f and search for downloadmirror (Which will take you to the location of the wget command)
-Add the argument --no-check-certificate
In addition to this addition, I've found that pip is required for this… and rather difficult to install on the Jetson TX2 system I'm using:
-Open up settings GUI (It can be done via CLI but you'd have to research this yourself)
-Open to page "Software & Updates"
-Make sure the option 'Community-maintained free and open-source software (universe)' is checked
-in the terminal you can now run:
~$sudo apt update
~$sudo apt-get install python3-pip
I'll add any more solutions as and when I encounter issues.
I also had to manually install h5py using pip:
~$sudo apt-get install python-h5py
and then removed its option from requirements.txt.
