6605 Discussions
encountering error with Stable diffusion + openvino and possible memory leak?
The_Chazz
Hello, I have having a bit of an issue with stable diffusion openvino.
I am getting my command shell filled with
torch._dynamo.symbolic_convert: [WARNING] C:\Users\----\Downloads\stable-diffusion-webui\venv\lib\site-packages\torch\nn\modules\linear.py <function Linear.forward at 0x000001C4CABA9BD0> [UserDefinedObjectVariable(LoraPatches), NNModuleVariable(), TensorVariable()] {} too many positional arguments
it also appears to be causing a memory leak as currently at the end of a generation of 20 steps with 20 hires steps my system is currently using 72.1GB/95.9GB system ram.
I followed https://github.com/openvinotoolkit/stable-diffusion-webui/wiki/Installation-on-Intel-Silicon
to get up and running.
PC info:
CPU Ryzen 9 x5950
96GB System Ram
Intel Arc A770
Windows 11 Pro 23H2
Megat_Intel
Hi The_Chazz,
For your information, I installed Stable Diffusion for OpenVINO™ following the same guide and I was able to run the txt2img with OpenVINO™ using my iGPU and did not encounter any errors. sd success .png
OS: Windows 11
Python: 3.10.6
GPU: Intel(R) UHD Graphics
torch: 2.1.0
There is a similar case where the error is caused due to the torch version incompatibility. Please check your torch version and try to install the torch version 2.1.0 and see if this fixes the "TensorVariable" issue. sd torch.png
Regarding the memory leak. I also observed the memory still being occupied after the image generation was completed. My Stable Diffusion program uses on average 3.5 GB of RAM and it stays that way. However, I noticed that the RAM usage goes down after a few minutes. Could you please try and wait for 5-10 minutes after the image generation is complete to see if the memory goes back to normal?
Megat
The_Chazz
thank you for your reply. can you provide instructions on how to upgrade torch to version 2.1.0+cpu? I am just an end user, and not really familiar with how to install dependencies etc.
thank you!
Megat_Intel
Hi The_Chazz,
To install the torch version 2.1.0, follow the steps below:
  1. cd stable-diffusion-webui
  2. venv\Scripts\activate
  3. pip install torch==2.1.0
On the other hand, to check the torch version installed on your device, you can validate by running the command:
pip show torch
Megat
Megat_Intel
Hi The_Chazz,
Thank you for your question. This thread will no longer be monitored since we have provided a suggestion. If you need any additional information from Intel, please submit a new question.
Megat
