error to run model
Megamind-5
Hi, I follow this step
https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_raspbian.html
but it cannot run the model I got this error.
How can I fix it?
Megamind-5
Hello, I know how to fix it now.
I need to get the right path for example
"./armv7l/Release/object_detection_sample_ssd -m /home/pi/build/open_model_zoo/tools/downloader/intel/face-detection-adas-0001/FP16/face-detection-adas-0001.xml"
Thank you anyway.
[ INFO ] InferenceEngine:
API version ............ 2.1
Build .................. 2021.3.0-2787-60059f2c755-releases/2021/3
Description ....... API
Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ] Loading Inference Engine
[ INFO ] Device info:
MYRIAD
myriadPlugin version ......... 2.1
Build ........... 2021.3.0-2787-60059f2c755-releases/2021/3
[ INFO ] Loading network files:
[ INFO ] Preparing input blobs
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the device
[ INFO ] Create infer request
[ WARNING ] Image is resized from (474, 252) to (672, 384)
[ INFO ] Start inference
[ INFO ] Processing output blobs
[0,1] element, prob = 0.999512    (280,83)-(338,162) batch id : 0 WILL BE PRINTED!
[1,1] element, prob = 0.990234    (161,89)-(216,160) batch id : 0 WILL BE PRINTED!
[2,1] element, prob = 0.986816    (40,84)-(97,163) batch id : 0 WILL BE PRINTED!
[3,1] element, prob = 0.980957    (399,83)-(456,162) batch id : 0 WILL BE PRINTED!
[4,1] element, prob = 0.0268555    (322,91)-(365,141) batch id : 0
[5,1] element, prob = 0.0258789    (445,118)-(476,177) batch id : 0
[6,1] element, prob = 0.0249023    (424,84)-(479,150) batch id : 0
[7,1] element, prob = 0.0219727    (353,88)-(393,145) batch id : 0
[8,1] element, prob = 0.0209961    (-6,227)-(28,258) batch id : 0
[9,1] element, prob = 0.0180664    (452,141)-(477,164) batch id : 0
[10,1] element, prob = 0.0170898    (323,140)-(339,160) batch id : 0
[11,1] element, prob = 0.0161133    (313,137)-(342,162) batch id : 0
[12,1] element, prob = 0.0161133    (230,32)-(399,226) batch id : 0
[13,1] element, prob = 0.015625    (295,78)-(324,110) batch id : 0
[14,1] element, prob = 0.015625    (304,78)-(335,104) batch id : 0
[15,1] element, prob = 0.015625    (452,99)-(477,122) batch id : 0
[16,1] element, prob = 0.015625    (451,110)-(477,133) batch id : 0
[17,1] element, prob = 0.015625    (451,130)-(478,152) batch id : 0
[18,1] element, prob = 0.015625    (296,135)-(335,162) batch id : 0
[19,1] element, prob = 0.015625    (455,151)-(477,174) batch id : 0
[20,1] element, prob = 0.015625    (29,196)-(48,230) batch id : 0
[21,1] element, prob = 0.015625    (53,212)-(102,254) batch id : 0
[22,1] element, prob = 0.015625    (165,211)-(217,254) batch id : 0
[23,1] element, prob = 0.015625    (399,158)-(463,283) batch id : 0
[24,1] element, prob = 0.0146484    (324,152)-(340,173) batch id : 0
[25,1] element, prob = 0.0146484    (172,67)-(200,91) batch id : 0
[26,1] element, prob = 0.0146484    (452,88)-(477,111) batch id : 0
Megamind-5
Thank you anyway.
MYRIAD
Iffa_Intel
Greetings,,
Glad to know that & thanks for sharing.
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
