6595 Discussions
error when compiling openCV 4.0 on ubuntu 18.04
Shintani__Eigo
When I try to compile openCV 4.0 source file, it is stopped by errors of
opencv-4.0.0/modules/dnn/src/dnn.cpp:1595:72: error: invalid new-expression of abstract class type ‘cv::dnn::InfEngineBackendNet’
                 net = Ptr<InfEngineBackendNet>(new InfEngineBackendNet());
opencv-4.0.0/modules/dnn/src/dnn.cpp:2556:78: error: invalid new-expression of abstract class type ‘cv::dnn::InfEngineBackendNet’
     backendNode->net = Ptr<InfEngineBackendNet>(new InfEngineBackendNet(ieNet));
/usr/include/c++/7/ext/aligned_buffer.h:52:25: error: cannot declare field ‘__gnu_cxx::__aligned_membuf<cv::dnn::InfEngineBackendNet>::_Tp2::_M_t’ to be of abstract type ‘cv::dnn::InfEngineBackendNet’
       struct _Tp2 { _Tp _M_t; };
This is done on ubuntu 18.04. Are there missing libraries ?
Best,
Eigo
Maksim_S_Intel
Looks like you have to set INF_ENGINE_RELEASE cmake variable to match your Inference Engine version. For example:
-DINF_ENGINE_RELEASE=2018050000
for Inference Engine from OpenVINO 2018R5.
Check cmake code and comments here and here.
Or you are using older OpenCV version which does not support newer Inference Engine interface. Try to update to 4.0.1 or master.
Shintani__Eigo
Hi Maksim,
I tried
$export INTEL_CVSDK_DIR=/opt/intel/computer_vision_sdk
$cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/usr/local -DINF_ENGINE_RELEASE=2018050455 ..
$make
but the same error message appeared.
OpenVINO is installed on /opt/intel/computer_vision_sdk_2018.5.455/
Best,
Eigo
Maksim_S_Intel
Did you try OpenCV 4.0.1? INF_ENGINE_RELEASE should be "2018050000".
Shintani__Eigo
Hi Maksim,
Yes, but it was the same situation. The whole error message is
/home/shintani/Downloads/opencv-4.0.0/modules/dnn/src/dnn.cpp: In member function ‘void cv::dnn::dnn4_v20180917::Net::Impl::initInfEngineBackend()’:
/home/shintani/Downloads/opencv-4.0.0/modules/dnn/src/dnn.cpp:1595:72: error: invalid new-expression of abstract class type ‘cv::dnn::InfEngineBackendNet’
In file included from /home/shintani/Downloads/opencv-4.0.0/modules/dnn/src/dnn.cpp:44:0:
/home/shintani/Downloads/opencv-4.0.0/modules/dnn/src/op_inf_engine.hpp:44:7: note:   because the following virtual functions are pure within ‘cv::dnn::InfEngineBackendNet’:
 class InfEngineBackendNet : public InferenceEngine::ICNNNetwork
/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/inference_engine/include/ie_icnn_network.hpp:190:24: note:     virtual InferenceEngine::StatusCode InferenceEngine::ICNNNetwork::serialize(const string&, const string&, InferenceEngine::ResponseDesc*) const
     virtual StatusCode serialize(const std::string &xmlPath, const std::string &binPath, ResponseDesc* resp) const noexcept = 0;
/home/shintani/Downloads/opencv-4.0.0/modules/dnn/src/dnn.cpp: In static member function ‘static cv::dnn::dnn4_v20180917::Net cv::dnn::dnn4_v20180917::Net::readFromModelOptimizer(const String&, const String&)’:
/home/shintani/Downloads/opencv-4.0.0/modules/dnn/src/dnn.cpp:2556:78: error: invalid new-expression of abstract class type ‘cv::dnn::InfEngineBackendNet’
BTW, for openCV 3.4.4 it does not matter.
Best,
Eigo
Maksim_S_Intel
Your error message points to class declaration on line 44, it was on this line in version 4.0.0 and had shifted to line 45 in version 4.0.1. So you are still building with version 4.0.0 which does not support OpenVINO 2018R5. Please try version 4.0.1 and make sure you make a clean build (create new build directory).
Shintani__Eigo
Hi Maksim,
OK, could you tell me how i can get version 4.0.1 ?
Eigo
Green__Jim
No need to compile OpenCV.
OpenVINO for Linux has included OpenCV4.
Just set vars, and you will import cv2
