6598 Discussions
[facenet] not support normalize layer (fixed)
Wang__Bill
I successfully convert the facenet(20180402-114759) to XML/BIN.
However, the plugin said the normalize layer is not supported.
Is that true?
        plugin = IEPlugin(device='CPU', plugin_dirs=None)
        if args.cpu_extension and 'CPU' in args.device:
            plugin.add_cpu_extension(args.cpu_extension)
        net = IENetwork.from_ir(model=facenet_model_xml, weights=facenet_model_bin)
        if "CPU" in plugin.device:
            supported_layers = plugin.get_supported_layers(net)
            not_supported_layers = [l for l in net.layers.keys() if l not in supported_layers]
            if len(not_supported_layers) != 0:
                print("Following layers are not supported by the plugin for specified device {}:\n {}".
                      format(plugin.device, ', '.join(not_supported_layers)))
                print(
                    "Please try to specify cpu extensions library path in sample's command line parameters using -l "
                    "or --cpu_extension command line argument")
                sys.exit(1)
facenet link https://drive.google.com/file/d/1EXPBSXwTaqrSC0OhUdXNmKSh9qJUQ55-/view
openvino: computer_vision_sdk_2018.3.343
python 3.5
tensorflow 1.11.0
Wang__Bill
I use cpu_extension which can support the normalize layer.
kao__mars
Hi Bill,
i have the same issue.
Can i know how to build the cpu_extension which can support normalize layer?
kao__mars
i can read the model by set cpu_extension which build by sample project.
Shubha_R_Intel
Dear kao, mars,
According to the Supported Devices document the Normalize layer is definitely supported on CPU, GPU and VPU. You should add the cpu_extension.dll (*.so) in your code ( I see it in the version of code you pasted above). Once you do, it should fix the problem.
Does it work for you ?
Shubha
Shubha_R_Intel
Dear kao, mars,
I noticed that your title says "fixed".  Thanks for reporting back to the community that your issue is now fixed.
Shubha
kao__mars
Hi Shubha,
thanks for your reply.  After i load the  cpu extension, it can get the facenet model output well. But i found that it can't support the dynamic batch if the model need the extension (ex. model define the "normalize" layer in the last layer).
the document says:
Do not use layers that might arbitrary change tensor shape (such as Flatten, Permute, Reshape), layers specific to object detection topologies (ROIPooling, ProirBox, DetectionOutput), and "custom layers".
Any suggestion for this case?
