6593 Discussions
fp16 model inference ”memory data type alignment do not match”
Hou_y_1
Hi
  I converted caffemodel into IR with this command “./ModelOptimizer -p FP16  -w $1 -d $2 -i -b 1 -f 1 ”; Then i run samples with this model, the command line is "./multi_output_sample  -i armstrong_128.bmp -m my_model_fp16.xml -ni 100 -d GPU", but i get a error:
         [ INFO ] Start inference (1 iterations)
          terminate called after throwing an instance of 'std::logic_error'
          what():  memory data type alignment do not match
          Aborted (core dumped)
I see the sample code
     for (int iter = 0; iter < FLAGS_ni; ++iter) {
            auto t0 = Time::now();
            status = enginePtr->Infer(inputBlobs, outputBlobs, &resp);
            auto t1 = Time::now();
            fsec fs = t1 - t0;
            ms d = std::chrono::duration_cast<ms>(fs);
            total += d.count();
            if (status != InferenceEngine::OK) {
                throw std::logic_error(resp.msg);
        /** Show performace results **/
        std::cout << std::endl << "Average running time of one iteration: " << total / static_cast<double>(FLAGS_ni) << " ms" << std::endl;
the error shows  failure to infer, how can i save this problem?
Anna_B_Intel
Does it work if you run this model on CPU?
We can help you if you share your model with us. Is it possible?
Best wishes,
Anna
