6585 Discussions
google.protobuf.text_format.ParseError: 1426:17 : Couldn't parse float: 0.0F
I have trained models on my dataset several times, and convert the dataset to graph success,
but this time,
it has an error like this,
it seems there is a 0.0F couldn't be convert , but I have trained the same model several times and just change a larger dataset,
Have you meet the same problem before?.
Thanks for your time and look for your reply
@zufeifei I haven't seen this issue before. For further clarification, you mentioned that you are able to convert the model to Movidius graph format? What are you doing when you see this issue (compiling/checking/profiling/inference using the NCSDK API)?
