6594 Discussions
how quickly convert a model (*.py) to a graph and upload to NCS2
TNguy219
Hi
I have this model
http://www.chezmoi.dk/upload/YOLOV3-Tutorial-master.zip  (8MB)
https://i.imgur.com/ekvadYd.png
yolov3.weights, 248MB download from https://pjreddie.com/media/files/yolov3.weights
It ran successful on Google Colab. I want now implement this on my Windows10 with an "Intel NCS2"
How can i convert my trained model to a graph file on my windows 10 and upload to NCS2?
I this a quick/smart way to do it, is this possible? please help.
NB: I cant run on the model on my laptop due to an old nvidia card.
d:\_events\big data\object detection with tensorflow\YOLOV3-Tutorial-master>python tutorialDetect.py --images circus.jpg --det output
Loading network.....
Network successfully loaded
Traceback (most recent call last):
 File "tutorialDetect.py", line 97, in <module>
   model.cuda()
 File "D:\Program Files\Python37\lib\site-packages\torch\nn\modules\module.py", line 265, in cuda
   return self._apply(lambda t: t.cuda(device))
 File "D:\Program Files\Python37\lib\site-packages\torch\nn\modules\module.py", line 193, in _apply
   module._apply(fn)
David_C_Intel
Hi TNguy219,
Thanks for reaching out.
First you need to install the latest OpenVINO™ toolkit release (refer to this link for Windows* 10 installation). Then, use the model optimizer, you can check this Yolo* models guide for converting your YoloV3 model to IR format using this tool. After obtaining your IR files, you can run inference on the Intel® Neural Compute Stick 2.
You can use the Object Detection YOLO* V3 Python* Demo to test your model with the Intel® Nerual Compute Stick 2.
If you have more questions let us know.
David C.
A Contingent Worker at Intel
David_C_Intel
Hi TNguy219,
David C.
TNguy219
Hello David C,
Thanks for the reply and the guide, i manage to make it. I wrote a guide on my language, which you can see here
https://drive.google.com/file/d/1pUsvsmX1-Y4dC0zfW6x59aHTqaf7kZ7F/view
look at page 30, the chapter "Covert và optimize pre-train model để load vào NCS2 Usb Stick"
You dont need to understand the language, look at the screendumps and the links.
I need to change 3 files before it works. Thanks to some posts i found from the Intel forum, all are list in the doc.
yolo_v3.json
d:\Program Files (x86) 2\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\front\tf\extractor.py
d:\Program Files (x86) 2\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\middle\passes\fusing\decomposition.py
Still too slow, I need to switch to yolov3-tiny, it is a lot better. But i think my old laptop need to decode the video stream so it takes extra time, better with a webcam, so no decode, only raw data from the cam.
Hoping this help for other who will try NCS2 in the future.
ps: if you plan to make a NCS3, please do it so it is backward compatible (openvino) and it will be great if it is a "single computer board", just like "Odroid XU4" (jetson nano).
THANKS
Tuan
David_C_Intel
Hello TNguy219,
Thank you for your reply.
Great job by doing that guide on your own! Now more people can read and understand more about how OpenVINO™ toolkit works.
The Object Detection YOLO* V3 Python* Demo you checked is able to detect objects on images as well. You also can modify the ".py" code for it to read a directory with images inside.
In case you have additional questions, be free to ask.
David C.
