6592 Discussions
i got following error while installing caffe on ncsdk directory
[ 0%] Building CXX object src/caffe/CMakeFiles/proto.dir///include/caffe/proto/caffe.pb.cc.o
In file included from /opt/movidius/ssd-caffe/build/include/caffe/proto/caffe.pb.cc:5:0:
/opt/movidius/ssd-caffe/build/include/caffe/proto/caffe.pb.h:12:2: error: #error This file was generated by a newer version of protoc which is
/opt/movidius/ssd-caffe/build/include/caffe/proto/caffe.pb.h:13:2: error: #error incompatible with your Protocol Buffer headers. Please update
/opt/movidius/ssd-caffe/build/include/caffe/proto/caffe.pb.h:14:2: error: #error your headers.
/opt/movidius/ssd-caffe/build/include/caffe/proto/caffe.pb.h:23:35: fatal error: google/protobuf/arena.h: No such file or directory
compilation terminated.
src/caffe/CMakeFiles/proto.dir/build.make:74: recipe for target 'src/caffe/CMakeFiles/proto.dir///include/caffe/proto/caffe.pb.cc.o' failed
make[3]: *** [src/caffe/CMakeFiles/proto.dir///include/caffe/proto/caffe.pb.cc.o] Error 1
make[3]: Leaving directory '/opt/movidius/ssd-caffe/build'
CMakeFiles/Makefile2:235: recipe for target 'src/caffe/CMakeFiles/proto.dir/all' failed
make[2]: *** [src/caffe/CMakeFiles/proto.dir/all] Error 2
make[2]: Leaving directory '/opt/movidius/ssd-caffe/build'
Makefile:127: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/opt/movidius/ssd-caffe/build'
Installation failed. Error on line 498
pls help me out____
@Hashir
If you ask questions, write about the environment in detail.
The error message says:
your headers.
So please try the following.
$ protoc --version <show protobuf version> $ sudo apt update $ sudo apt upgrade $ protoc --version <show protobuf version> $ make install
The version you need depends on whether Ubuntu or Raspbian.
If the above command does not work, try the command below.
Install libprotobuf 3.5.1.
$ cd ~ $ wget https://github.com/google/protobuf/releases/download/v3.5.1/protobuf-all-3.5.1.tar.gz $ tar -zxvf protobuf-all-3.5.1.tar.gz $ cd protobuf-3.5.1 $ ./configure $ sudo make -j1 $ sudo make install $ cd python $ export LD_LIBRARY_PATH=../src/.libs $ python3 setup.py build --cpp_implementation $ python3 setup.py test --cpp_implementation $ sudo python3 setup.py install --cpp_implementation $ sudo ldconfig $ protoc --version $ cd <ncsdk folder path> $ make install
If you do not do the above command, it is suspected of conflict with pycaffe or other.
https://ncsforum.movidius.com/discussion/comment/2994/#Comment_2994
https://ncsforum.movidius.com/discussion/comment/3027/#Comment_3027
◆Ubuntu16.04
https://packages.ubuntu.com/search?keywords=libprotobuf-dev&searchon=names&suite=xenial&section=all
◆Raspbian
https://packages.debian.org/search?suite=stretch&section=all&arch=any&searchon=names&keywords=libprotobuf-dev
