6584 Discussions
i want to know when i can use ncsdk2 in raspi4?
zangu
JesusE_Intel
Hi zangu,
I'm glad that you are able to use OpenVINO with the RPi. You can find the demos from the following link: https://github.com/opencv/open_model_zoo/tree/master/demos
We also have pre-trained networks that can be downloaded with the model_downloader. A list of all the pre-trained networks and compatible demos application can be found here:
https://github.com/opencv/open_model_zoo/tree/master/demos#demos-that-support-pre-trained-models
Take a look at this guide as it contains great information about the model downloader and the model optimizer for RPi.
https://software.intel.com/en-us/articles/model-downloader-optimizer-for-openvino-on-raspberry-pi
Hope this helps!
Jesus
JesusE_Intel
Hi zangu,
The Intel Neural Compute SDK (Intel NCSDK) has only been tested on the Raspberry Pi 3 with Raspbian Stretch. There are currently no plans to test the NCSDK on the RPi4, please give it a try and share the results with the community.
Also, there are no further updates planned for the Intel NCSDK as the OpenVINO toolkit supports both the Intel Movidius Neural Compute Stick and the Intel Neural Compute Stick 2. It is more likely that the OpenVINO toolkit works with the RPi 4.
Hope this helps!
Jesus
zangu
Hi Jesus,
I tried NCSDK in RPi4, it look's like not suport newest system.
Then i tried use OpenVINO toolkit and Intel Movidius Neural Compute Stick, i succeed!
Also, i am trying how to do object detection whit OpenVINO like NCSDK.
If there any where can get this, plese tell me.Thank you!
zangu
JesusE_Intel
Hi zangu,
Hope this helps!
Jesus
zangu
Hi Jesus,
Thank you so much for your help!
I'll try the demos in RPi4.
Zangu
