iGPU cant be detected of core i7-13700
jasonsloan
Hi All:
As the official mentions above, the core i7-13700 processor which I use should have integrated graphic inside, but when I want to list all the available devices by openvino, I cant find the "iGPU", how to fix it?
The code I use is below, and it only list the "CPU" device
from openvino.runtime import Core
ie = Core()
devices = ie.available_devices
for device in devices:
    device_name = ie.get_property(device, "FULL_DEVICE_NAME")
    print(f"{device}: {device_name}")
Aznie_Intel
Hi Jasonsloan,
Thanks for reaching out. Have you configure Intel® Processor Graphics (GPU) with OpenVINO™? Refer to this instruction to use a GPU device for OpenVINO inference.
You may check the available GPU using the code below:
import openvino as ov
core = ov.Core()
core.available_devices
device = "GPU"
core.get_property(device, "FULL_DEVICE_NAME")
Aznie
jasonsloan
Hi Aznie!
Very thankful for your help.
I followed your instruction link to install the GPU driver and etc.
But after that, I still couldnt detect the iGPU using the code you provided above via openvino.
The detail of my environment is below:
os:                                              Rocky Linux release 9.3 (Blue Onyx)
cpu:                                            13th Gen Intel(R) Core(TM) i7-13700
openvino version:                                  2023.3 LTS
clinfo:                                              Number of platforms 0
besides, the packages within the red rectangles below are all installed successfully
the output of the avalaible devices of openvino:
I checked the information of command "hwinfo --display", and I found maybe "the driver is not active " is the reason.
I tried to fix it with the suggested command "modprobe i915" and it failed again:
How to solve the problem?
Im looking forward to your reply! Thanks a lot!
Aznie_Intel
Hi Jasonsloan,
We are checking on this and will get back to you soon.
Aznie
Aznie_Intel
Hi Jasonsloan,
Thanks for your patience. Our engineering team is looking at the issue from the driver perspective. However, the actual root case was that the user didn’t have the right permission for the operation. Can you try to execute the operation with the root access? Get back to us if you still encounter the same issue in root access.
Aznie
Aznie_Intel
Hi Jasonsloan,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
