ie_api.so library not compiled
OKI__HIdetaka
Hi,  I built dldt from github source tree. I can not find ie_api.so in dldt/inference-engine/bin/{arch}/Release/ or dldt/inference-engine/build/ .
When installing OpenVINO SDK with the binary package downloaded from Intel site, it is located in /opt/intel/openvino/python/python?.?/{arch}/openvino/inference_engine/ .
Do I need to execute "cmake ; make" in the indivisual directory , not only at the top level - dldt/inference-engine/build/ ?
OKI__HIdetaka
Hi, I found the guide in dldt/inference-engine/ie_bridges/python/README.md and successfully built ie_api.so for x86-64 arch.
Somehow an infinite nesting problem occurs in pyconfig.h of python3.5m during cross compilation for another arch.  This might have nothing to do with dldt source, so I will check my cross compilation environment..
Kenneth_C_Intel
Yes, I think it may have been an issue in your environment.
I found ie_api.so in dldt/inference-engine/bin/intel64/Release/lib/python_api/python3.6/openvino/inference_engine.
If you find an issue that the cmake script fails in please let us know so we can address it.
OKI__HIdetaka
Hi, thank you for reply.
I fixed /usr/include/aarch64-linux-gnu/python3.5m/ link in my environment and built ie_api.so in dldt/inference-engine/bin/arm64/Release/lib/python_api/python3.5/openvino/inference_engine/ successfully.
My target plarform is arm 64 ubutu box and I use Xeon ubuntu server for cross compilation due to memory and file system limitation on the box. Compiling x86-64 binary is just for reference to check cmake and make behavior.
I am now strugling another problem to build opencv. Executing "cmake ; make" finishes normally and libopencv*.so libraries and opencv* commands are built,  but cv2.cpython-35m-aarch64-linux-gnu.so is not built. I can build cv2.python-35m-x86_64-linux-gnu.so to run self compilation with the same cmake arguments on the same server. OpenVINO SDK binary package.includes cv2.cpython-{ver}-{arch}.so , so I suppose it would be required
OKI__HIdetaka
I have built cv2.python-35m-{arch}-linux-gnu.so on cross compiling environment with some addtional "Define"s of python directories and pkg-config directory in cmake arguments to follow information messages from cmake. The generated .so file name is cv2.cpython-x86_64-linux-gnu.so but it is "ELF 64-bit LSB shared object, ARM aarch64, version 1 (SYSV), dynamically linked, not stripped".
This name is declared in sevral scripts in opencv/build/modules/python3/  which are generated by cmake. It seems that the arch infix is named for HOST_SYSTEM_PROCESSOR, not for target SYSTEM_PROCESSOR. I can not figure out how to modify infix naming in cmake scripts or so, but it should not be big deal since it could just be renamed when deploying.
