I trained a caffe MobileNet-SSD model with my own dataset based on https://github.com/chuanqi305/MobileNet-SSD .
The model works perfect if I load it with cv2.dnn.readNetFromCaffe and CPU.
However, when I load it with cv2.dnn.readNetFromCaffe and MYRIAD, the results are different and less accurate. Any suggestion?
The below codes are run on Raspberry Pi stretch with opencv '4.1.0-openvino' and NCS2:
#!/usr/bin/env python3
import json
import cv2
def decode_out(out):
detections = []
for data in out[0,0,:,:]:
if float(data[2]) > 0.3:
detections.append({
"bbox": [float(x) for x in data[3:]],
"score": float(data[2]),
"class_id": int(data[1])
return sorted(detections,key=lambda x:x['score'], reverse=True)
image = cv2.imread("/home/pi/test.jpg")
image = cv2.resize(image, (300,300))
input_blob = cv2.dnn.blobFromImage(image, 1.0/127.5, (300,300), (127.5, 127.5, 127.5), False, False)
model = "/home/pi/no_bn.caffemodel"
prototxt = "/home/pi/no_bn.prototxt"
net = cv2.dnn.readNetFromCaffe(prototxt, model)
# wiht CPU
net.setPreferableTarget(cv2.dnn.DNN_TARGET_CPU)
net.setPreferableBackend(cv2.dnn.DNN_BACKEND_OPENCV)
net.setInput(input_blob)
out1 = net.forward()
print(json.dumps(decode_out(out1),indent=2))
# with NCS2
net.setPreferableBackend(cv2.dnn.DNN_BACKEND_INFERENCE_ENGINE)
net.setPreferableTarget(cv2.dnn.DNN_TARGET_MYRIAD)
out2 = net.forward()
print(json.dumps(decode_out(out2),indent=2))
Dear fu, cfu,
Did you use the "--input_shape" command-line parameter in your model optimizer command ? Usually when detection is off, that is the reason. Please make sure you pass in a proper value which exactly matches the image size the model was trained on.
Also, did you do any pre-processing on your images before training ? Please see my detailed answer to this post
Shubha
Hi Shubha,
Thanks for the response. In fact, I am not using the model optimizer in this case, instead I am using the caffe model only.
The issue is that the outputs are different with CPU and MYRIAD(NCS2), and the CPU one is way better.
Dear fu, cfu,
OK I see.
This forum is meant for Model Optimizer and Inference Engine, which forms the core of OpenVino. For OpenCV questions, please post your questions here :
https://github.com/opencv/opencv/issues
https://answers.opencv.org/questions/
Thanks !
Shubha
