install failed on older laptop
I have an older core2duo laptop I wanted to do just the mnvcomplie on.
But when I tried to install the latest version it failed.
I am running unbuntu 16.04 Any ideas
Ign:74 http://security.ubuntu.com/ubuntu xenial-security/multiverse arm64 Packages
Err:59 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
404 Not Found [IP: 91.189.88.162 80]
Ign:68 http://security.ubuntu.com/ubuntu xenial-security/universe arm64 Packages
Fetched 323 kB in 2s (126 kB/s)
Reading package lists…
W: Invalid 'Date' entry in Release file /var/lib/apt/lists/_var_libopencv4tegra-repo_Release
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.162 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Installation failed: Command ' apt-get update' return code=100. Error on line 308 in ./install-utilities.sh. Will exit
@chicagobob123 Looks like the NCSDK install is failing during the sudo apt-get update part of the NCSDK install. Likely you have some packages with broken/outdated links. Try changing the update server to the main server (go to System Settings, then Software and Updates, then in the drop down menu for Download from: choose main server). Afterwards try sudo apt-get update again.
You can also try a fresh install if it is an option.
