6597 Discussions
install libgtk2.0-dev and pkg-config, then re-run cmake or configure script in function 'cvShowImage
heebahsaleem
I have installed openvino and deployed blob into it but when i am executing. I am getting below error.
I have tried everything that i available on internet, installed the packages as well but nothing works
OS: Ubuntu 20.04
Error
2024-01-16 17:51:29.889857: I tensorflow/tsl/cuda/cudart_stub.cc:28] Could not find cuda drivers on your machine, GPU will not be used.
2024-01-16 17:51:29.911350: I tensorflow/tsl/cuda/cudart_stub.cc:28] Could not find cuda drivers on your machine, GPU will not be used.
2024-01-16 17:51:29.911607: I tensorflow/core/platform/cpu_feature_guard.cc:182] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
To enable the following instructions: AVX2 FMA, in other operations, rebuild TensorFlow with the appropriate compiler flags.
2024-01-16 17:51:30.349034: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:38] TF-TRT Warning: Could not find TensorRT
[INFO] initializing a depthai camera pipeline...
[INFO] initializing pipeline...
[INFO] initializing traffic light signal classifier network...
[INFO] Creating Color Camera...
[INFO] Creating ImageManip node...
Traceback (most recent call last):
File "classify_camera.py", line 91, in <module>
cv2.imshow("rgb", frame)
cv2.error: OpenCV(4.5.3-openvino) ../opencv/modules/highgui/src/window.cpp:1239: error: (-2:Unspecified error) The function is not implemented. Rebuild the library with Windows, GTK+ 2.x or Cocoa support. If you are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-run cmake or configure script in function 'cvShowImage'
Peh_Intel
Hi Heebahsaleem,
The encountered error is due to there is some conflict with OpenCV. May I know which OpenCV you’re using?
Peh
heebahsaleem
>>> import cv2
>>> cv2.__version__
'4.5.3-openvino'
Peh_Intel
Hi Heebahsaleem,
Where do you download the OpenCV 4.5.3-openvino?
I am able to run OpenCV with OpenCV 4.5.3-openvino, which included in Intel® Distribution of OpenVINO™ toolkit 2021.4.2.
Please ensure that you update OpenVINO™ environment variables by running the command below before importing OpenCV.
source /opt/intel/openvino_2021/bin/setupvars.sh
Peh
heebahsaleem
Hi Peh_Intel
Thank you for your reply.
I did as you said, but nothing works. I am really new to OpenVino.
As per the error, I have also tried installing libgtk2.0-dev and pkg-config, but it didn't work.
Your help will be highly appreciated.
Peh_Intel
Hi Heebahsaleem,
Can you try testing the basic OpenCV function with OpenCV 4.5.3-openvino?
Try with the following commands:
  1. source /opt/intel/openvino_2021/bin/setupvars.sh
  2. python3
  3. import cv2
  4. image = cv2.imread("AnyPathToAnImage.jpeg")
  5. cv2.imshow("Image",image)
  6. cv2.waitKey(0)
Peh
heebahsaleem
thank you for your reply^^
Please see the output below. It is same:
heebahsaleem
I fixed the warnings.
Peh_Intel
Hi Heebahsaleem,
For OpenVINO™ 2021.4.2, it only supports Python 3.6 - 3.8.
To proceed to use Python 3.11, you have to install OpenVINO™ 2023.2. For OpenVINO™ 2023.2, OpenCV is not include in the archives. However, you can download OpenCV package, pip install opencv-python .
Peh
heebahsaleem
thank you for your reply.
Yes, that's correct that OpenVino 2021.4.2 only supports Python 3-6 3.8 and hence I have installed Python version 3.8.
I do not want to use OpenVino 2023.2 version, because as per the documentation there is no blob converter for this version and I may have to use some tags which might not work, therefore 2021 could work right away.
References:
https://discuss.luxonis.com/d/2642-compile-tool-for-openvino-20231/8
https://discuss.luxonis.com/d/1196-neuralnetwork0-warning-input-image-224x224-does-not-match-nn-3x224/20
Peh_Intel
Hi Heebahsaleem,
From your last screenshot, I noticed that you're importing Python 3.11.5.
Can you try creating a virtual environment and re-run OpenCV?
  1. python3 -m venv openvino_env
  2. source openvino_env/bin/activate
  3. source /opt/intel/openvino_2021/bin/setupvars.sh
  4. pip install numpy
  5. python3
  6. import cv2
  7. image = cv2.imread("AnyPathToAnImage.jpeg")
  8. cv2.imshow("Image",image)
  9. cv2.waitKey(0)
Peh
heebahsaleem
Hi Peh_Intel
After lot of multiple attempt, I am able to solve the issue by uninstalling libtiff.
Thank you for your time and help^^
Peh_Intel
Hi Heebahsaleem,
Glad to know your issue has been resolved.
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Peh
