issue with Raspberry 3 sample
Hi all,
i followed https://ncs-forum-uploads.s3.amazonaws.com/ncsdk/MvNC_SDK_01_07_07/NCS_Getting_Started_1.07.07.pdf instructions but when i try:
pi@raspberrypi:~/mvnc_1.07.07/ncapi/py_examples/stream_infer $ python3 stream_infer.py
** (stream_infer.py:1137): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
Number of categories: 1000
Device 0 Address: 1.3.1 - VID/PID 03e7:2150
Starting wait for connect with 2000ms timeout
Found Address: 1.3.1 - VID/PID 03e7:2150
Found EP 0x81 : max packet size is 512 bytes
Found EP 0x01 : max packet size is 512 bytes
Found and opened device
Performing bulk write of 825136 bytes…
Successfully sent 825136 bytes of data in 53.779255 ms (14.632241 MB/s)
Boot successful, device address 1.3.1
Found Address: 1.3.1 - VID/PID 040e:f63b
done
Booted 1.3.1 -> VSC
The windows appear but seams to be freezed, any suggestion?
Thank you in advance
Paolo
Sorry, i simply substituted the webcam and everything's went well
