6597 Discussions
issues on using post_training_optimization_toolkit with faster_rcnn_resnet50_coco
Lin__Joey
Innovator
Dear someone,
I am testing the openVino 2020.2, released just few days ago, on its post training optimization tool functions.
I followed the README.md (see attachment) in the sample config folder, and  picked up the faster_rcnn_resent50_coo.yaml
for accuracy check test. I updated the sample config file with the path of downloaded val2017, and annotation file instances_val2017.json.
Finally, I ran the command,
python main.py -c  faster_rcnn_resnet50_coco.yaml
The error shows I must specify model name, launchers, datasets (see attached JPEG). It seems like that I have messed up with the path, but whatever I tried
, no improvement has been made.  Could some one help figure out what went wrong?
The error:
~\post_training_optimization_toolkit>python main.py -c faster_rcnn_resnet50_coco.yaml
raise ConfigError('Each model must specify {}'.format(', '.join(required_model_entries)))
libs.open_model_zoo.tools.accuracy_checker.accuracy_checker.config.config_validator.ConfigError: Each model must specify name, launchers, datasets
Thanks in advance,
Joey Lin
SIRIGIRI_V_Intel
Can you confirm that you have followed the installation steps for Post-Training Optimization Toolkit.
Please follow the documentation and provide the config file with parameters required.
Ram prasad
SIRIGIRI_V_Intel
Ram prasad
Lin__Joey
Innovator
Hi, Ram:
Thank you for the documentation link. I followed the steps and successfully optimized faster_rcnn_resnet50_coco model.
regards,
Joey
