make examples error for NCSDK2.04
Hello
I am running Ubuntu 16.04.4 (fresh installed). I downloaded NCSDK2.04 and did make install. That was built successfully. However when I did make examples it gives me the following error:
Traceback (most recent call last):
File "/usr/local/bin/mvNCProfile", line 155, in
profile_net(args.network, args.inputnode, args.outputnode, args.nshaves, args.inputsize, args.weights, args.device_no, args.explicit_concat, args.ma2480, args.scheduler, args)
File "/usr/local/bin/mvNCProfile", line 141, in profile_net
timings, myriad_output = run_myriad(graph_file, args)
File "/usr/local/bin/ncsdk/Controllers/MiscIO.py", line 96, in run_myriad
devices = mvncapi.enumerate_devices()
AttributeError: module 'mvnc.mvncapi' has no attribute 'enumerate_devices'
Makefile:64: recipe for target 'profile' failed
make[3]: *** [profile] Error 1
make[3]: Leaving directory '/home/baishali/ncsdk2_04/ncsdk/examples/caffe/AlexNet'
Makefile:12: recipe for target 'AlexNet' failed
make[2]: *** [AlexNet] Error 2
make[2]: Leaving directory '/home/baishali/ncsdk2_04/ncsdk/examples/caffe'
Makefile:13: recipe for target 'caffe/.' failed
make[1]: *** [caffe/.] Error 2
make[1]: Leaving directory '/home/baishali/ncsdk2_04/ncsdk/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
My system path for python is this:
sys.path
['', '/home/baishali', '/opt/movidius/caffe/python', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/home/baishali/.local/lib/python2.7/site-packages', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/gtk-2.0']
Can somebody help me with this issue
can you try with python3 ?
Hi @baishali, can you give us some more information about your installation process? Did you previously have an older version of the NCSDK installed?
mvnc.enumerate_devices - is used in ncssdk2
while mvnc.EnumerateDevices is used in ncssdk1 , error could be due to mismatch SDK and code.
check Path envrioment if both SDK is installed
