make: *** [mobilenet-ssd] Error 2`
Hello ,
I am a newbie to movidius neural compute stick2 and I am following this tutorial, https://software.intel.com/en-us/neural-compute-stick/tutorials
I cloned the repository ncappzoo. I get the following error when I tried the command make run
/bin/sh: 6: mvNCCompile: not found Makefile:106: recipe for target 'compile' failed make[1]: *** [compile] Error 127 make[1]: Leaving directory '/home/workspace/ncappzoo/caffe/SSD_MobileNet' Makefile:10: recipe for target 'mobilenet-ssd' failed make: *** [mobilenet-ssd] Error 2
Is there a way to solve this?
Thanks in advance.
make run \making ilsvrc12 (cd ../../data/ilsvrc12; make;) make[1]: Entering directory '/home/brp/intel_compute/workspace/ncappzoo/data/ilsvrc12' make[1]: Leaving directory '/home/brp/intel_compute/workspace/ncappzoo/data/ilsvrc12' making googlenet (cd ../../caffe/GoogLeNet; make compile;) make[1]: Entering directory '/home/brp/intel_compute/workspace/ncappzoo/caffe/GoogLeNet' making prereqs (cd ../../data/ilsvrc12; make) make[2]: Entering directory '/home/brp/intel_compute/workspace/ncappzoo/data/ilsvrc12' make[2]: Leaving directory '/home/brp/intel_compute/workspace/ncappzoo/data/ilsvrc12' making prototxt Prototxt file already exists making caffemodel caffemodel file already exists making compile mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt make[1]: mvNCCompile: Command not found Makefile:80: recipe for target 'compile' failed make[1]: *** [compile] Error 127 make[1]: Leaving directory '/home/brp/intel_compute/workspace/ncappzoo/caffe/GoogLeNet' Makefile:26: recipe for target 'googlenet' failed make: *** [googlenet] Error 2
Hi @sprinzzzz
If you are using the Intel Neural Compute Stick 2 (NCS 2) you will need to use the OpenVINO Toolkit. The Neural Compute SDK you are installing only has support for the original Neural Compute Stick.
Take a look at the Getting Started Guide for NCS 2.
Jesus
