module 'openvino' has no attribute 'Node'
ShinobuHUYUGIRI
I'm using OpenVINO for the first time.
I would like to convert an ONNX model to an OpenVINO model quantized in INT8. However, when I run "nncf.quantize", the following message appears and the conversion fails.
How can I solve this?
  File "/media/shino/KIOXIA/mobilenetv2_cat_and_dog/openvino/3.5_test.py", line 38, in <module>
    quantized_model = nncf.quantize(
AttributeError: module 'openvino' has no attribute 'Node'
import os
import nncf
from PIL import Image
import numpy as np
from openvino.runtime import Core, serialize
ONNX_MODEL_PATH = "../cat_and_dog_mobilenetv2.onnx"
cats_dir = "../test_dir/cats"
dogs_dir = "../test_dir/dogs"
def preprocess_image(image_path, input_size=(224, 224)):
    image = Image.open(image_path).convert("RGB")
    image = image.resize(input_size)
    image = np.array(image).astype(np.float32) / 255.0
    image = np.transpose(image, (2, 0, 1))
    image = np.expand_dims(image, axis=0)
    return image
def get_calibration_data():
    image_paths = []
    for folder in [cats_dir, dogs_dir]:
        for fname in os.listdir(folder):
            if fname.endswith((".jpg", ".jpeg", ".png")):
                image_paths.append(os.path.join(folder, fname))
    for image_path in image_paths:
        yield [preprocess_image(image_path)]
calibration_dataset = nncf.Dataset(get_calibration_data())
onnx_model_path = ONNX_MODEL_PATH
core = Core()
ov_model = core.read_model(onnx_model_path)
    model=ov_model,
    calibration_dataset=calibration_dataset,
    preset=nncf.QuantizationPreset.MIXED,
    target_device=nncf.TargetDevice.CPU
serialize(quantized_model, "model_int8.xml", "model_int8.bin")
The following versions of Python, OpenVINO, nncf, and other Python packages are used:
$ python3.12 -m venv ~/env/openvino_new
$ . ~/env/openvino_new/bin/activate
$ pip install --upgrade pip
$ pip install openvino==2024.4.0 openvino-dev==2024.4.0 nncf==2.17.0 numpy==1.26.4 opencv-python==4.8.0.76 onnx==1.16.2 onnxruntime==1.18.0 matplotlib==3.9.2 scikit-learn==1.5.2 pillow==10.4.0 seaborn==0.13.2
ShinobuHUYUGIRI
The cause of this issue seems to be an old version of nncf. Installing nncf 2.8.0 solved the issue.
Thank you!
$ pip install openvino==2024.6.0 openvino-dev==2024.6.0 optimum[onnx]==1.12.0 nncf==2.8.0 numpy==1.26.4 opencv-python==4.8.0.76 onnx==1.16.2 onnxruntime==1.18.0 matplotlib==3.9.2 scikit-learn==1.5.2 pillow==10.4.0 seaborn==0.13.2
ShinobuHUYUGIRI
Thank you!
Zulkifli_Intel
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
