multi-batch latency comparative experiment
shirleyliu
I want to test the relationship between batch size and parallel computing on GPU. I did the following experiment
device: GPU(Intel UHD Graphics 630)
model input shape: (1,3,8,8)
input image shape:(8,8)
my command is like this:
python ./benchmark_app.py -m xxx_8x8_fp16_b1.xml -i 0801_8x8.png -d GPU -api sync -niter 1000 -b batchsize
I need to focus on latency so I set the -api synchronize mode
and the only thing I need to do is to change the batch size, the test result is in the following chart
batchsize
8
16
32
64
128
256
512
1024
1200
1280
1300
1500
1536
2000
2048
3000
3500
3700
3850
3900
4000
4096
Inputshape
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
8x8
GPU usage
50%
53.5%
59%
68%
75%
83%
89%
95%
94%
97%
94%
95%
98%
97%
98%
97.5
98%
99%
99%
98%
100%
100%
latency
0.35
0.39
0.51
0.66
0.86
1.38
2.57
6.54
5.7
9.94
5.96
6.80
13.19
9.56
19.19
14.23
17.41
17.76
18.68
18.61
41.57
42.41
and look at the bold numbers. It's strange that the result doesn't show the regularity of the latency increases with the increase of batch size. and specifically, if the batch size is in a particular size, the GPU usage is slightly reduced and the latency is reduced a lot
could you please give me some advice on this phenomenon?thanks
Labels (2)
Peh_Intel
Hi shirleyliu,
Thank you for your patient.
Our GPU development team has looked into this reported behavior and based on their inputs, in general such behavior may occur because when changing the batch, other kernels and/or other parameters for blocking may be selected. As per today, they have not looked into such batches in details with their main priority is batch size = 1. Recently, they are starting into looking into bigger ones for discreet GPU but it was basically 32 and 64.
We hope above explanations suits your needs.
Peh
Peh_Intel
Hi Shirley,
Thanks for reaching out to us and sharing your findings.
First and foremost, I unable to run Benchmark App with model by changing to a very high batch size due to exceeding the max size of memory object allocation as the models in Intel Public Model is trained with large input shape (227x227). Hence, I do not have models with very small input shape for duplicating your issues.
Could you share your model with us for further investigation?
Besides, try to specific the same number of streams and carry out the experiment again:
python ./benchmark_app.py -m xxx_8x8_fp16_b1.xml -i 0801_8x8.png -d GPU -api sync -niter 1000 -b batchsize -nstreams 1
Peh
shirleyliu
Thanks, I have tried to set nstreams = 1, but the phenomenon is similar.
Peh_Intel
Hi Shirley,
Thanks for sharing your model with us.
I also obtained the unexpected results when running Benchmark App with your model on GPU Plugin.
However, running Benchmark App with your model on CPU Plugin resulting in desired results which in obtained latency increasing with the increasing of batch sizes. You can have a look on the attached picture.
As such, we will investigate this unexpected behavior and get back to you at the earliest.
Peh
shirleyliu
Peh_Intel
Hi Shirley,
We had channeled this issue to our development team for better explanation on such behavior. It might take some time and we will get back to you once we received some feedbacks.
Peh
Peh_Intel
Hi Shirley,
We received an update from our developers that they will only look at this unexpected behavior in the beginning of January 2022 as their current resources are focused to enable 2022.1 release.
As per today, we will keep this case open until we obtain updates from them.
Peh
shirleyliu
Thank you very much. and Let me know if they have any results
Peh_Intel
Hi shirleyliu,
Peh
Peh_Intel
Hi shirleyliu,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Peh
