mvNCCompile MTCNN issue
hi
I try to convert RNET model file into a graph file, but I got the error log show as below
command I flash is : "mvNCCompile rnet-3000000.meta -s 12 -in input -on output -o rnet.graph"
LOGS:
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py:766: DeprecationWarning: builtin type EagerTensor has no module attribute
EagerTensor = c_api.TFE_Py_InitEagerTensor(_EagerTensorBase)
/usr/local/lib/python3.5/dist-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() instead
if d.decorator_argspec is not None), _inspect.getargspec(target))
WARNING:tensorflow:The saved meta_graph is possibly from an older release:
'local_variables' collection should be of type 'byte_list', but instead is of type 'node_list'.
Traceback (most recent call last):
File "/usr/local/bin/mvNCCompile", line 118, in
create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights)
File "/usr/local/bin/mvNCCompile", line 104, in create_graph
net = parse_tensor(args, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 227, in parse_tensor
inputTensor = graph.get_tensor_by_name(inputnode + ':0')
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 3207, in get_tensor_by_name
return self.as_graph_element(name, allow_tensor=True, allow_operation=False)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 3035, in as_graph_element
return self._as_graph_element_locked(obj, allow_tensor, allow_operation)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/ops.py", line 3077, in _as_graph_element_locked
"graph." % (repr(name), repr(op_name)))
KeyError: "The name 'input:0' refers to a Tensor which does not exist. The operation, 'input', does not exist in the graph."
Below I attach model github link
https://github.com/wangbm/MTCNN-Tensorflow/tree/master/save_model/sepatate/rnet
