6594 Discussions
mvNCCompile for self-defined activation function
Hello
Can mvNCCompile support self-defined activation function? We have some self-defined activation functions which are running under pytorch and these functions are not supported under Caffe. Is it possible that we can convert the NN model into NCS internal format?
@chenmagi Thank you for your interest in using the NCS with your project. At the moment, we don't support user defined functions for the NCS, but I can definitely make a note of this for a future consideration.
Thank you, Tome.
By the way, is it the same limitation for MDK?
@chenmagi You can contact https://www.movidius.com/contact for more information regarding the MDK.
