mvcNCCompile no works
HI everyone, i installed de NCSDK v2 and when i try make the examples or compile caffe model no working this stays loading… i have connected the movidius in the port
@jdavidguerrero Hi, what OS did you install the NCSDK on? What type of machine or embedded platform are you working on? Can you please provide a log of the issue you are experiencing? Thanks!
Hi, excuse me the platform is mi pc with ubuntu 16.04 (No Virtualbox)
@Tome_at_Intel Looks this stays here in terminal
making compile
mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
@Tome_at_Intel do you have idea that what happens ?
@jdavidguerrero Can you try running the hello_ncs example and copy and paste the log here? Also to make sure your NCS is being detected, can you do a dmesg or lsusb check and copy and paste the log here also.
@Tome_at_Intel look the output is strange, because my pc recognize the stick
Output dmesg
[ 983.609091] usb 2-4: new high-speed USB device number 2 using xhci_hcd
[ 983.762981] usb 2-4: New USB device found, idVendor=03e7, idProduct=2150
[ 983.762987] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 983.762991] usb 2-4: Product: Movidius MA2X5X
[ 983.762994] usb 2-4: Manufacturer: Movidius Ltd.
[ 983.762996] usb 2-4: SerialNumber: 03e72150
Output of hello_ncs.py
D: [ 0] ncDeviceCreate:307 ncDeviceCreate index 0
D: [ 0] ncDeviceCreate:307 ncDeviceCreate index 1
D: [ 0] ncDeviceOpen:501 File path /usr/local/lib/mvnc/MvNCAPI-ma2450.mvcmd
I: [ 0] ncDeviceOpen:507 ncDeviceOpen() XLinkBootRemote returned success 0
I: [ 0] ncDeviceOpen:536 XLinkConnect done - link Id 0
D: [ 0] ncDeviceOpen:550 done
I: [ 0] ncDeviceOpen:552 Booted 4-ma2450 -> VSC
I: [ 0] getDevAttributes:373 Device attributes
I: [ 0] getDevAttributes:376 Device FW version: 2.4.2450.f0
I: [ 0] getDevAttributes:378 mvTensorVersion 2.4
I: [ 0] getDevAttributes:379 Maximum graphs: 10
I: [ 0] getDevAttributes:380 Maximum fifos: 20
I: [ 0] getDevAttributes:382 Maximum graph option class: 1
I: [ 0] getDevAttributes:384 Maximum device option class: 1
I: [ 0] getDevAttributes:385 Device memory capacity: 522073264
Hello NCS! Device opened normally.
I: [ 0] ncDeviceClose:742 closing device
Goodbye NCS! Device closed normally.
NCS device working.
