mxlk kernel module
lisovoy__andrey
Hi. I try to use Advantech VEGA-330 miniPCIe board with two Myriad X MA2485.
Dldt code (dldt/inference-engine/thirdparty/movidius/XLink/pc/pcie_host.c) suggests me that mxlk module must be loaded.
I found it in OpenVINO 2020.1 (deployment_tools/inference_engine/external/myriad/drivers) and build into Ubuntu 18 (kernel is 4.15.0-88-generic).
It loads with errors:
[62610.664094] mxlk: loading out-of-tree module taints kernel.
[62610.664141] mxlk: module verification failed: signature and/or required key missing - tainting kernel
Module apeears in lsmod, but folder /sys/class/mxlk/ is empty.
So, what can i do to run OpenVINO with VEGA-330 on Ubuntu 18?
SIRIGIRI_V_Intel
Hi Andrey,
Can you confirm that you have installed dependencies for MYRIAD.
Ram prasad
lisovoy__andrey
No. But board works over USB. Thanks for trying to help.
