nan output values when using FP16
Deepak_C_R
I have following custom kernel function.
kernel void fooBar
    const __global float* input,
    int     num_dims_in,
    const __global int* dims_in,
    const __global int* stride_in,
    float     offset_x,
    __global float* output,
    int     num_dims_out,
    const __global int* dims_out,
    const __global int* stride_out
  int w = dims_in[0];
  int h = dims_in[1];
  int x = get_global_id(0);
  int y = get_global_id(1);
  int z = get_global_id(2);
  int index = x + y * w + z * w * h;
  output[index] = (input[index] > 0) ? input[index] : input[index] * offset_x ; //Here
  return ;
This program is working fine with optimized FP32 model format.
But when I am converting the model into FP16 floating point format (using MO) I am getting all my final layer output as nan values.
I am thinking the error is coming from my kernel function given above.
If I am writing
output[index] = (input[index] > 0) ? input[index] : input[index] * 0;
instead of
I am getting non nan values.
Can somebody help me with this ?
Deepak_C_R
I was able to fix this by using vstore_half() and vload_half(). Also by using data type half instead of float.
Earlier multiplication by offset_x was converting the data into 32 bit floating point format.
Deepak Chembakassery Rajendran
Deepak_C_R
I have modified my function as follows:
kernel void foobar (
    const __global half* input,
    int num_dims_in,
    float     offset_x,
    __global half* output,
    int     num_dims_out,
  int w = dims_in[0];
  int h = dims_in[1];
  int d = dims_in[2];
  vstore_half((( vload_half(index, input) > 0) ? vload_half(index, input): vload_half(index, input) * offset_x), index, output);
  return ;
This is working fine, I am getting proper output.
