6587 Discussions
ncappzoo build get [Fail] with Obtained value
ncsdk has been built in Ubuntu 16.04 x64. ncappzoo is build with make, with one NCS is pluged in.
When build TensorFlow InceptionV2, I get some [Fail] logs as follows (I don't change anything):
A.
make[2]: Entering directory '/home/guan/NCS/ncappzoo/tensorflow/inception_v2'
Generating Profile Report 'output_report.html'…
USB: Transferring Data…
USB: Myriad Execution Finished
USB: Myriad Connection Closing.
USB: Myriad Connection Closed.
Result: (1, 1, 1001)
1) 1000 nan
2) 328 nan
3) 341 nan
4) 340 nan
5) 339 nan
Expected: (1, 1001)
1) 947 0.999625
2) 808 0.000375067
3) 791 1.48096e-09
4) 229 1.08099e-11
5) 790 3.16383e-13
/usr/local/bin/ncsdk/Controllers/Metrics.py:75: RuntimeWarning: invalid value encountered in greater
diff)) / total_values * 100
Obtained values
Obtained Min Pixel Accuracy: nan% (max allowed=2%), Fail
Obtained Average Pixel Accuracy: nan% (max allowed=1%), Fail
Obtained Percentage of wrong values: 0.0% (max allowed=0%), Fail
Obtained Pixel-wise L2 error: nan% (max allowed=1%), Fail
Obtained Global Sum Difference: nan
diff)) / total_values * 100 seems to be the underlying problem… I guess.
B.
make[2]: Entering directory '/home/guan/NCS/ncappzoo/tensorflow/mobilenets'
1) 600 0.77051
2) 886 0.06131
3) 905 0.053284
4) 893 0.018265
5) 906 0.0092926
Expected: (1, 1001)
1) 600 0.723252
2) 886 0.0944978
3) 905 0.0332514
4) 893 0.022707
5) 790 0.0145219
Obtained values
Obtained Min Pixel Accuracy: 6.53381422162056% (max allowed=2%), Fail
Obtained Average Pixel Accuracy: 0.02274659782415256% (max allowed=1%), Pass
Obtained Percentage of wrong values: 0.2997002997002997% (max allowed=0%), Fail
Obtained Pixel-wise L2 error: 0.2732927306157317% (max allowed=1%), Pass
Obtained Global Sum Difference: 0.16467970609664917
Here I get 2 Fail and 2 Pass.
I have built it twice and the problem is always the same. Is it some BUGs in ncappzoo?
@iceguan You're right about a bug in the ncappzoo example. Thanks for bringing this to our attention.
