6597 Discussions
ncappzoo: can't compile on a Docker instance of ncsdk
I am running ncsdk in a docker container on a Ubuntu 16.04 based system. After testing that the ncsdk works over the USB connection, I am trying to install and work on an image classifier example as described in: https://movidius.github.io/blog/ncs-image-classifier/
After I git cloned the ncappzoo archive into /ncsdk/workspace/, I tied to do a
make compile
from the /ncsdk/workspace/ncappzoo directory. This fails with the following error message:
/usr/local/bin/ncsdk/Controllers/FileIO.py:65: UserWarning: You are using a large type. Consider reducing your data sizes for best performance
Blob generated
make[2]: Leaving directory '/ncsdk/workspace/ncappzoo/tensorflow/inception_v3'
make -C tf_models/. compile
make[2]: Entering directory '/ncsdk/workspace/ncappzoo/tensorflow/tf_models'
make[2]: *** No rule to make target 'compile'. Stop.
make[2]: Leaving directory '/ncsdk/workspace/ncappzoo/tensorflow/tf_models'
Makefile:12: recipe for target 'tf_models/.' failed
make[1]: *** [tf_models/.] Error 2
make[1]: Leaving directory '/ncsdk/workspace/ncappzoo/tensorflow'
Makefile:12: recipe for target 'tensorflow/.' failed
make: *** [tensorflow/.] Error 2
What can I do to make this work? I have tried deleting the entire workspace directory and cloning again from github, but no luck: see the same error again. Have any one of you tried to build ncappzoo on a docker container instance of ncsdk? Is this a supported flow?
@kalyan_s Have you taken a look at https://movidius.github.io/ncsdk/docker.html? Please let me know if this works for you.
