We have installed and tried some sample demo applications and its working fine. But when we tried with our own in-build model we faced some issues. pls help to solve that. i have attached the screenshots also.
issue: " Conversion of the model(maybe due to variable size input of model)(in case of object_Detection) is creating the issue. Even it is created, then the model is not able to load correctly. If the model is loaded correctly(in case of yolo_v3), then ie_api.pyx error is shown. "
The original model of Object Detection is converted to the Inference Engine format. But the issue of ie_api.pyx is still there. we have tried ubuntu also but same issue.
Can you please suggest on this. Also please find the attachment openvino.rar.
Zuhair
Hello, Mohamed,
From your screen shot of error message, I assume you use the faster-rcnn which has the proposal layer, and the proposal layer support requires you to point to the extension. Please refer to the ssd python sample under the "<OpenVINO_root>/deployment_tools/inference_engine/samples/python_samples/object_detection_sample_ssd/object_detection_sample_ssd.py" to understand how to use the latest "IECore" class and linking to the extension file.
