openvino multi-process
samllBlack
The time of multi-process calls to openvino in 2024 has skyrocketed, for example, when two processes call openvino to deploy the same model, the time of a single inference has doubled. What should I do about it
Iffa_Intel
Could you clarify:
  1. Which OpenVINO sample application/code are you using?
  2. Which model are you using for this use case? (if possible, please help to share details of model(eg custom model/pretrained model), relevant model files and conversion steps that you did)
  3. Your OS and hardware details
  4. How did you measure the processing time?
  5. What is your expected time/benchmark timing for the processing?
  6. Does this recently happened where previously it work as expected?
Cordially,
Iffa
Iffa_Intel
Thank you for your question.  If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
