pip3 install --proxy usage?
Ping-Chuan_L_Intel
On windows 10 platform to run this batch file that seems pulling in python library failing socket connection?
C:\Intel\computer_vision_sdk_2018.2.304\deployment_tools\demo>demo_squeezenet_download_convert_run.bat
Python 3.6.5
ECHO is off.
Collecting pyyaml
  Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ProtocolError('Connection aborted.', ConnectionResetError(10054, 'An existing connection was forcibly closed by the remote host', None, 10054, None))': /simple/pyyaml/
Try out pip3 install numpy --proxy PROXY-SERVER:PORT_NUMBER with real proxy server name and port number still no luck?
Appreciate if can get help?
Monique_J_Intel
Hi Ping-Chuan,
This link should help and if all else fails then you could just set the proxy environment variable by doing the following via command line:On
set http_proxy=http://<proxyHost>:<proxyPort>
set https_proxy=https://<proxyHost>:<proxyPort>
Kind Regards,
Monique Jones
Ping-Chuan_L_Intel
Magic!
I set both environment variables then the problem solved.
Thanks very much!
Ping
