plugin.get_supported_layers
yu__jin
HI~
I  installed the OpenVINO 2020.1 and I built the demo successfully and also run well for MYRIAD (use -d MYRIAD).
I have got my own onnx model and IR file(xml, bin).
Then I run the python script like this:
from openvino.inference_engine import IENetwork, IEPlugin
plugin=IEPlugin(device='MYRIAD')
testxml="/home/ryz/Pictures/siamfc.xml"
testbin="/home/ryz/Pictures/siamfc.bin"
net=IENetwork(model=testxml, weights=testbin)
sup_layers=plugin.get_supported_layers(net)
no_sup = [i for i in net.layers.keys() if i not in sup_layers]
print(no_sup)
then I got this result:     ['actual_input_1']
the layer-actual_input_1  in xml file like this:
        <layer id="0" name="actual_input_1" type="Parameter" version="opset1">
            <data element_type="f16" shape="1,3,127,127"/>
            <output>
                <port id="0" precision="FP16">
                    <dim>1</dim>
                    <dim>3</dim>
                    <dim>127</dim>
                    <dim>127</dim>
                </port>
            </output>
        </layer>
 I am confused... so what's wrong with this layer?
Best regards.
yu__jin
And when i change the
to plugin=IEPlugin(device='CPU').
All layers are supported.
SuryaPSC_Intel
Hi Jin,
Can you share what type of model you are using?
Surya
yu__jin
Chauhan, Surya Pratap Singh (Intel) wrote:
Hi Jin,
Surya
I convert the siamfc pytorch model to onnx. It's a target tracking model.
Some operations in siamfc are not supported by openvino.
so when I convert the onnx to IR, I do the Model Cutting.
python3 mo.py --input_model siamfc.onnx --input=actual_input_1 --output=46
I don't konw what's wrong with actual_input_1 layer
            <output>
                    <dim>1</dim>
                    <dim>3</dim>
                    <dim>127</dim>
                    <dim>127</dim>
                </port>
            </output>
        </layer>
SuryaPSC_Intel
Hi Jin,
Siamese network is not a supported pytorch model via onnx conversion.
Also, layers support vary from device to device. Kindly refer to Supported Layers.
Surya
