program C5P with aocx using JTAG
MMoha9
i have an openvino starter kit , and i want to do inferences on  the FPGA (CYCLONE 5 ). the board name is C5P <=> OSK. I am confused about how to program the bitstream file .aocx. I am using ubuntu 16.04 and i installed all the required software and toolkit as mentioned in the manual provided by terasic and intel.  i have a question about programming the AOCX file: should connect my board to a PCIe or i can just program the fpga using the jtag cable. i tried the command "aocl diagnose" and i got "FAILED DIAGNOSE " , is it normal because the board is not connected to the PCIE ??
thanks in advance
Shubha_R_Intel
Dear Oussayran, Mohamad,
As I mentioned in your previous post the Cyclone is not a supported OpenVino  FPGA platform so an intel person will not be able to help you here on this forum. However there may be someone in the community that can help you.
Shubha
