6614 Discussions
python 2.7 support for OpenVino Version 2020.2
lin__chia_hao
Python 2.7 support is still listed on the document, but after install, I only find python3+ directories under python/
Is Python 2.7 support dropped from this version or it will still be supported in the future?
Edit: I don't know why this is moved from openvino to here, but hopefully I can get some info here
Munesh_Intel
Hi Jotarun,
Python 2.7 is among the supported versions of Inference Engine Python API on Ubuntu 16.04 and 18.04 OSes.
More information is available at the following page:
https://docs.openvinotoolkit.org/2020.3/_inference_engine_ie_bridges_python_docs_api_overview.html#supported_oses
As for your query regarding future support, regrettably, we are unable to comment on that. We apologize for any inconvenience caused.
Munesh.
lin__chia_hao
Hi Munesh,
Thanks for your reply.
I understand you can't comment about future plan,
But my main problem is that 2.7 is not working with 2020.2 right now, although listed in the document.
in 2020.1, there is a 2.7 directory under python/ which are the codes support 2.7,
that is not available in 2020.2
Munesh_Intel
Hi Chia Hao,
I would suggest you use OpenVINO version 2020.1 if you want to continue using Python 2.7 since it was working for you.
More information regarding the required software components for Intel® Distribution of OpenVINO™ toolkit is available at the following link under the section 'Additional Software Requirements'.
https://www.intel.com/content/www/us/en/develop/tools/openvino-toolkit/system-requirements.html
Munesh
