"No devices found" with ncs
Hi.
ncsdk 'make install' was done. Running 'make examples', could see error '[Error 7] Toolkit Error: USB Failure. Code: No devices found'
Using Ubuntu 16.04 on Virtual box/Windows10. ncs was detected as “MA2X5X serial no. 03E72150” Would you please advise how to fix this error ?
/usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance
"Consider reducing your data sizes for best performance\033[0m")
test -f graph || mvNCCompile -s 12 output/inception-v1.meta -in=input -on=InceptionV1/Logits/Predictions/Reshape_1
make[3]: Leaving directory '/home/mssong/workspace/ncsdk/examples/tensorflow/inception_v1'
make[2]: Leaving directory '/home/mssong/workspace/ncsdk/examples/tensorflow'
make -C data/.
make[2]: Entering directory '/home/mssong/workspace/ncsdk/examples/data'
Possible Make targets
make help - shows this message
make clean - Removes all temp files from all directories
make[2]: Leaving directory '/home/mssong/workspace/ncsdk/examples/data'
make[1]: Leaving directory '/home/mssong/workspace/ncsdk/examples'
mssong@mssong-VirtualBox:~/workspace/ncsdk$
Best Regards
@mssong Please make sure that you have the following configurations specified at VM config and make sure you have set both USB filters (It looks like you already have at least one filter). Two filters are needed because the NCS device switches from USB2 to USB3 when being accessed. Please post your dmesg/lsusb logs here when plugging in the NCS device and trying to run the hello_ncs app.
I recently bought the ncs 2 and work on ubuntu 18.04
I'm facing the same problem and i can't find any issue.
Here is my lsusb/dmesg
lsusb
Bus 004 Device 002: ID 05e3:0616 Genesys Logic, Inc. hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 010: ID 03e7:2485
Bus 003 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04f3:21d5 Elan Microelectronics Corp.
Bus 001 Device 002: ID 8087:0a2b Intel Corp.
Bus 001 Device 004: ID 0c45:6713 Microdia
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg
[ 5492.595636] usb 1-1: new high-speed USB device number 7 using xhci_hcd
[ 5492.744228] usb 1-1: New USB device found, idVendor=03e7, idProduct=2485
[ 5492.744234] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5492.744238] usb 1-1: Product: Movidius MyriadX
[ 5492.744242] usb 1-1: Manufacturer: Movidius Ltd.
[ 5492.744246] usb 1-1: SerialNumber: 03e72485
[ 5794.139616] usb 1-1: USB disconnect, device number 7
[ 5796.716509] usb 3-1.1: new high-speed USB device number 10 using xhci_hcd
[ 5796.817305] usb 3-1.1: New USB device found, idVendor=03e7, idProduct=2485
[ 5796.817311] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5796.817315] usb 3-1.1: Product: Movidius MyriadX
[ 5796.817319] usb 3-1.1: Manufacturer: Movidius Ltd.
[ 5796.817323] usb 3-1.1: SerialNumber: 03e72485
Ping
hatem@hatem-Dell:~/workspace/ncsdk/examples/apps/hello_ncs_py$ make run
making run
python3 hello_ncs.py;
Error - no NCS devices detected, verify an NCS device is connected.
But still i can't ping the stick.
I tried both ncsdk and ncappzoo
Thank you for your help
Hatem
Hi @hatem_K
The Intel OpenVINO toolkit is the default software development kit for the Intel Neural Compute Stick 2. The NCSDK only supports for the original Neural Compute Stick.
You will need to download and install OpenVINO using the following instructions:
https://software.intel.com/en-us/neural-compute-stick/get-started
You can find additional information on the OpenVINO Forums:
https://software.intel.com/en-us/forums/computer-vision
Jesus
