6584 Discussions
rtsp very slow in face_recognition_demo from openvino 2020.3
aicha
hello intel,
I am a student just starting to use openvino toolkit and trying to run the face recognition demo from the open model zoo . the demo runs fine when using the pc camera .. but it is wery very slow when I use rtsp of an ip camera .. please help me solve this.
Thank you in advance .
Syamimi_Intel
Hi Aicha Ezzahra Sassi,
Please check your data rate excluding inference workload. This issue might be due to a slow incoming data rate.
Other than that, this issue might be due to using NCS2 as an inference device which can slow the output rate. You can try run the face_recognition_demo using a different device.
Syamimi
Vladimir_Dudnik
data rate of rtsp or IP connection might be slow, obviously demo can't work faster then incoming data rate
aicha
hello Vladimir, thank you for your response.
The demo works very well when I use usb camera. Do you have any solution for the slow performance of the rtsp ? or any alternative to it ?
( I use i7 8th gen intel processor and intel neural compute stick 2)
I will be greatefull to you if you can help me with that.
Vladimir_Dudnik
Syamimi_Intel
I have validated face_recognition_demo using an IP camera and it works fine. For your information, I am using the IP Webcam application to run the demo.
The demo run slow maybe because data rate of RTSP or IP connection is slow.
Syamimi
aicha
hello @Syamimi_Intel ,
thank you for your response. But I didn't find any solution for that till now .
regards.
aicha
Syamimi_Intel
Syamimi
Syamimi_Intel
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Syamimi
