runtime error in model usage
pkhan10
hello
i have trained ssd object detector with backbone of mobilenetv2
I was able to convert model using model optimizer, using following script
python mo_tf.py --input_model /media/prateek/prateek_space/model_files/person_detection/2020_07_03_mobilenet_v2/inference_graph/frozen_inference_graph.pb --tensorflow_object_detection_api_pipeline_config ~/prateek_space/model_files/person_detection/2020_07_03_mobilenet_v2/inference_graph/pipeline.config --input_shape [1,3,300,300] -o ~/prateek_space/model_files/openvino_model/2020_07_03_person_detection/ --transformations_config extensions/front/tf/ssd_support_api_v1.15.json --reverse_input_channels
I am getting following runtime error while using the model, please help
Max_L_Intel
Hi @pkhan10
Okay, in that case please modify your command in the following way
python mo_tf.py --input_model /media/prateek/prateek_space/model_files/person_detection/2020_07_03_mobilenet_v2/inference_graph/frozen_inference_graph.pb --tensorflow_object_detection_api_pipeline_config ~/prateek_space/model_files/person_detection/2020_07_03_mobilenet_v2/inference_graph/pipeline.config --input_shape [1,300,300,3] -o ~/prateek_space/model_files/openvino_model/2020_07_03_person_detection/ --transformations_config extensions/front/tf/ssd_support_api_v1.15.json --reverse_input_channels
I am able to successfully convert your model and then do a test inference on it with the benchmark app. Please test this with your application.
Best regards, Max.
Max_L_Intel
Hi @pkhan10
Weights dimensions are {16,3,3,3}, but input is {1,300,3,300}.
Either weights should have the dimensions {16,300,3,3} or input should be {1,3,3,300} (--input_shape [1,3,300,3] in your command since you use NHWC format).
Hope this helps.
Best regards, Max.
pkhan10
Hey max,
thanks for responding back
attaching all model files here including pipeline.config
as you can see input shape is (300,300),
then as per that --input_shape in model optimizer should be [1,3,300,300]
i have attached model files aswell,
Can you please tell me write approach
pkhan10
model weights and pipeline
Max_L_Intel
Hi @pkhan10
Best regards, Max.
