6592 Discussions
training_extensions New installation two errors?
DaveBGld
Following instructions from [quick start guide](https://github.com/openvinotoolkit/training_extensions/blob/develop/QUICK_START_GUIDE.md), did the following:
`git clone https://github.com/openvinotoolkit/training_extensions.git
```cd training_extensions
git checkout -b develop origin/develop
The last line results in error:
> **fatal: A branch named 'develop' already exists**
Seems to me this is an error in the script to fetch the repo.
I still went ahead and run
`git submodule update --init --recursive`
> Submodule 'external/deep-object-reid' (https://github.com/openvinotoolkit/deep-object-reid) registered for path 'external/deep-object-reid/submodule'
> Submodule 'external/mmdetection' (https://github.com/openvinotoolkit/mmdetection) registered for path 'external/mmdetection/submodule'
> Submodule 'external/mmsegmentation' (https://github.com/openvinotoolkit/mmsegmentation) registered for path 'external/mmsegmentation/submodule'
> Submodule 'external/model-preparation-algorithm/submodule' (https://github.com/openvinotoolkit/model_preparation_algorithm) registered for path 'external/model-preparation-algorithm/submodule'
> Cloning into '/home/david/Downloads/training_extensions/external/deep-object-reid/submodule'...
> Cloning into '/home/david/Downloads/training_extensions/external/mmdetection/submodule'...
> Cloning into '/home/david/Downloads/training_extensions/external/mmsegmentation/submodule'...
> Cloning into '/home/david/Downloads/training_extensions/external/model-preparation-algorithm/submodule'...
> Submodule path 'external/deep-object-reid/submodule': checked out '8376d3ec0d3ceaf540020a070661739cddd9110b'
> Submodule path 'external/mmdetection/submodule': checked out 'ca19197237ab5ecb7e7a27514bd4f464f6d379a6'
> Submodule path 'external/mmsegmentation/submodule': checked out '571a0d38069588787916c682d94888614352972b'
> Submodule path 'external/model-preparation-algorithm/submodule': checked out '8d36bf5944837b7a3d22fc2c3a4cb93423619fc2'
Then after
`find external/ -name init_venv.sh`
and
TASK_ALGO_DIR=./external/mmsegmentation/
bash $TASK_ALGO_DIR/init_venv.sh ./cur_task_venv python3.8
source ./cur_task_venv/bin/activate
pip3 install -e ote_cli/ -c $TASK_ALGO_DIR/constraints.txt
And then
`ote find --root $TASK_ALGO_DIR`
results in error **ModuleNotFoundError: No module named 'ote_sdk'**:
> (segmentation) david@AI01:~/Downloads/training_extensions$ ote find --root $TASK_ALGO_DIR
> Traceback (most recent call last):
> File "/home/david/Downloads/training_extensions/cur_task_venv/bin/ote", line 11, in <module>
> load_entry_point('ote-cli', 'console_scripts', 'ote')()
> File "/home/david/Downloads/training_extensions/cur_task_venv/lib/python3.8/site-packages/pkg_resources/__init__.py", line 489, in load_entry_point
> return get_distribution(dist).load_entry_point(group, name)
> File "/home/david/Downloads/training_extensions/cur_task_venv/lib/python3.8/site-packages/pkg_resources/__init__.py", line 2852, in load_entry_point
> return ep.load()
> File "/home/david/Downloads/training_extensions/cur_task_venv/lib/python3.8/site-packages/pkg_resources/__init__.py", line 2443, in load
> return self.resolve()
> File "/home/david/Downloads/training_extensions/cur_task_venv/lib/python3.8/site-packages/pkg_resources/__init__.py", line 2449, in resolve
> module = __import__(self.module_name, fromlist=['__name__'], level=0)
> File "/home/david/Downloads/training_extensions/ote_cli/ote_cli/tools/ote.py", line 22, in <module>
> from .demo import main as ote_demo
> File "/home/david/Downloads/training_extensions/ote_cli/ote_cli/tools/demo.py", line 25, in <module>
> from ote_sdk.configuration.helper import create
I installed successfully in a fresh ubuntu install, so  in a think this is because I already have some python libraries that conflict, but before I reinstall my main development compute was hoping for some guidance.
Thanks!
Peh_Intel
Hi DaveBGld,
The command: git checkout -b develop origin/develop has been removed 2 days ago. More details about the error can refer to this Stack Overflow discussion.
Regarding the error (ModuleNotFoundError: No module named 'ote_sdk'), you can run the setup file for OTE SDK.
cd ote_sdk
python3 setup.py install
cd ..
Peh
DaveBGld
Did as you recommend, and completed with no errors, but ote is still unknown. I tried with a virtualenv and out using sudo.
TASK_ALGO_DIR=./external/mmdetection/
cd ote_sdk
Results in
Command 'ote' not found,
Is there a path I need to take care of?
Attaching the installation log with all commands:
Many thanks!!
Peh_Intel
Hi DaveBGld,
Previously, you have done the installation of ote_cli for the mmsegmentation but didn’t run the setup file for OTE SDK. Hence, received error: No module named ‘ote_sdk’.
Now, I noticed that you missed out the installation of ote_cli for mmdetection. Hence, the ote command is not found.
Peh
DaveBGld
Thanks for your reply.
I had installed ote.
In any case, I repeated by deleting the directory for venv, and run
That resulted in  error
error: invalid command 'bdist_wheel'
The complete console output is attached as extensions install try 1.txt
Deleted the venv and reinstalled, only this time installed wheel before ote
pip3 install wheel
But now another error:
ERROR: jupyter-client 7.3.1 has requirement python-dateutil>=2.8.2, but you'll have python-dateutil 2.8.1 which is incompatible.
The complete console output is attached as extensions install try 2.txt
Changed the ./external/mmdetection/constraints.txt so that python-dateutil==2.8.2
Deleted the venv again, and rerun, this time no errors except that running
results in error:
The complete console output is attached as extensions install try 3.txt
Could it be that the problem is with the venv creation/initialization?
Thanks again
Peh_Intel
Hi DaveBGld,
You are getting back the same error which can be solved by running the setup file for OTE SDK.
Please have a try again in your third virtual environment (extensions install try 3.txt) by running the commands below:
#open new terminal
cd <your_training_extension_directory>
cd ote_sdk
cd ..
Peh
DaveBGld
Thanks Peh! I ap[appreciate your patience.
I ran as you instructed and this time I get a different error:
ModuleNotFoundError: No module named 'torch'
The complete console output for all the commands is attached.
Peh_Intel
Hi DaveBGld,
Glad to hear that you’re making progress in setting up OpenVINO™ Training Extensions.
Have you tried to install PyTorch through the command below?
pip3 install torchvision
Peh
Peh_Intel
Hi DaveBGld,
This thread will no longer be monitored since we have provided solutions. If you need any additional information from Intel, please submit a new question.
Peh
