6605 Discussions
unable to play video file with openvino_2020.4.287
nmam
  • openvino version 2020.4.287
  • Downloaded opencv_videoio_ffmpeg440_64.dll (fciv of 3a46d6356220796e044817ae3a21cc31) using the ffmpeg-download.ps1 script present under the \IntelSWTools\openvino\opencv folder
  • compiled peopledetect.cpp sample. On running a video file I get this:
[ERROR:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2020.4\build\windows\opencv\modules\videoio\src\cap.cpp (142) cv::
VideoCapture::open VIDEOIO(CV_IMAGES): raised OpenCV exception:
OpenCV(4.4.0-openvino) C:\jenkins\workspace\OpenCV\OpenVINO\2020.4\build\windows\opencv\modules\videoio\src\cap_images.c
pp:253: error: (-5:Bad argument) CAP_IMAGES: can't find starting number (in the name of file): true in function 'cv::icv
ExtractPattern'
  •  changed peopledetect.cpp line 77 to
cap.open(file, cv::CAP_FFMPEG);
  •  with the above change I an getting this error:
C:\Program Files (x86)\IntelSWTools\openvino\opencv\samples\build>Release\openvino_sample_peopledetect.exe -v f:\tv2.mp4
[ WARN:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2020.4\build\windows\opencv\modules\core\src\utils\samples.cpp (59
) cv::samples::findFile cv::samples::findFile('true') => ''
Can not open video stream: 'true'
could you please advise on how to get past this issue ?  This is how I invoke the sample
Please do let me know in case you'd want more info form my env.
IntelSupport
Community Manager
Hi Neelabh Mam,
Thanks for reaching out.
We are able to replicate this issue and currently investigating it.
Aznie
IntelSupport
Community Manager
Hi Neelabh Mam,
Since this is OpenCV's sample, it should be invoked differently: openvino_sample_peopledetect.exe -v=f:\tv2.mp4
Besides, this is OpenCV's argument parser specific -all parameter should be separated by "=". The README file also suggests a long-form --video=<filename> which should work as well.
I have tested this and it works.
Aznie
nmam
IntelSupport
Community Manager
Hi Neelabh Mam,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
