unet
Deblauwe__Tom
In openvino R5, the unet model that is supported as indicated in the changelog of the release, is that a particular one, or, will for example this one work: https://github.com/jakeret/tf_unet
Tom,
Shubha_R_Intel
unet is supported (you can run a unet model through OpenVino's Model Optimizer to produce IR):
https://docs.openvinotoolkit.org/R5/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html
The recommended repo is different from yours:
https://github.com/kkweon/UNet-in-Tensorflow
Karthik_N_Intel
The link https://docs.openvinotoolkit.org/R5/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html is not working. Could you please share the updated link?
JesusE_Intel
Hi Karthik,
The link you mentioned points to a previous release of the documentation. The following is the same link on the latest version of the documentation.
https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html
Jesus
